Old 06-15-2021, 08:26 PM   #183
Code Monkey
Drives: Subaru BRZ
Originally Posted by Silviacrazed View Post
Planning to sell it? Or just don't feel like messing with harnesses anymore?
Will track with stock seat belts and see how I feel about it. I do have a GSpeed half cage that I have been thinking about installing for the last two years.
Code Monkey is offline   Reply With Quote
Old 06-24-2021, 01:01 PM   #184
Code Monkey
Drives: Subaru BRZ
Something made noise in the rear so I poked around and found that the hex bolt on both upper control arms loosened! I ordered new tie rod ends but could not remove the existing ones, they were seized! Took the arms to Gran Turismo East and they could not remove them either even with heat. Called Racer X and they told me that heating the arms probably ruined them so I ended up getting a new pair. Installed, aligned, and back on the road!
The Following User Says Thank You to Code Monkey For This Useful Post:
Silviacrazed (06-24-2021)
Old 06-24-2021, 04:58 PM   #185
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Needs more toe!
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following User Says Thank You to Opie For This Useful Post:
Code Monkey (06-24-2021)
Old 07-14-2021, 01:56 PM   #186
Code Monkey
Drives: Subaru BRZ
The clanking noise persisted so I poked around more and noticed the bushing on the FSB passenger side was melted. I suspect the initial damage happened when two of of three bolts on the Ace OP backed out and I got a nice exhaust leak there. I could not find a replacement bushing in stock, probably due to Covid shortages, so I purchased an entire brand new bar and got my bushing. Also, the tie rod boot got melted and I am still waiting for replacement parts to arrive....
Old 08-09-2021, 01:01 PM   #187
Code Monkey
Drives: Subaru BRZ
Replaced the melted inner tie rod boot, the clamp tool came in handy. Also changed the oil (1,659 miles and 3 track weekends since last oil change).
Doing Road Atlanta this weekend, then Barber and NCM in September.
Silviacrazed (08-09-2021)
Old 08-16-2021, 11:44 AM   #188
Code Monkey
Drives: Subaru BRZ
Great weekend at Road Atlanta.
Was running Kumho Ecsta V730 for the first time and the grip was great.
Did a 1:45.71 in 90-degree weather, maxing out at 115-117 mph on the back straight.
This is on OEM exhaust and tune, and no harness bar.
All time best is a low 1:43 on header/tune/e85, RE71, harness bar, doing about 126-127 on the back straight. Hoping to match or beat this time once the weather cools.
Opie (08-20-2021)
Old 08-18-2021, 05:24 PM   #189
Code Monkey
Drives: Subaru BRZ
Latest oil analysis. The sample was indeed taken after prolonged idling!
Opie (08-20-2021)
Old 09-06-2021, 07:17 PM   #190
Code Monkey
Drives: Subaru BRZ
Got tired of fixing torn wheel liners with Gorilla Tape so ordered custom wheel spacers from Motorsport Tech for 6ULs. 7mm thick, hubcentric to hub (56.1mm), wheelcentric to wheel (73.1mm). Due to shortages, it took 1.5 months to get the spacers but here they are (ordered 7/15, delivered 9/2).
Installed new fender liners and pre-emptively taped the problem areas with Gorilla Tape. Will see if the extra 7mm of offset eliminates the problem.
Silviacrazed (09-06-2021)
Old 09-06-2021, 07:21 PM   #191
Code Monkey
Drives: Subaru BRZ
September and October are going to be busy:
9/11-9/12 Barber
9/18-9/19 NCM
weekend off
10/2-10/3 Road Atlanta
weekend off
10/17-10/18 VIR
10/23-10/24 Road Atlanta
10/30-10/31 Barber
Changed front brake pads and will order another set + front rotors to have just in case.
Old 09-07-2021, 03:51 PM   #192
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
What offset wheels, tire size and camber were you having these issues with?
How did you get that camber? Just top hats, or camber bolts also?
Old 09-07-2021, 04:15 PM   #193
Code Monkey
Drives: Subaru BRZ
The wheels are 6UL, so 17x9 +40. Tires are 255/40. Running -3.8/-3.9 camber with camber plates and camber bolts.
Street wheels are APEX ARC-8 17x9 +42 but since I ordered wheel centric spacers, they will not work with the APEX rims.
timurrrr (09-07-2021)
Old 09-07-2021, 04:33 PM   #194
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Got it. I run 245/40 RE71Rs on 17x9 et40 König Hypergrams at ~ -3.2º camber (camber plates only) and haven't had that issue.
I did have the front tire rubbing behind the suspension against the chassis when going sideways with too much drift angle, even at et37.
Old 09-07-2021, 04:44 PM   #195
Code Monkey
Drives: Subaru BRZ
I do have rubbing on the chassis too, forgot to post pictures.
Old 09-12-2021, 10:55 PM   #196
Code Monkey
Drives: Subaru BRZ
JDL 4-2-1 header + CSG Zach tune.
The Following 5 Users Say Thank You to Code Monkey For This Useful Post:
jflogerzi (10-18-2021), Opie (09-15-2021), Silviacrazed (09-12-2021), Stonehorsw (09-13-2021), Thefalls (09-13-2021)
Berzerk's 2017 CWP 'Slow and Steady' Build Thread Berzerk Member's Car Journals 12 07-24-2017 05:57 PM
Rodie's slow '13 FR-S build rodie Member's Car Journals 0 06-14-2015 09:05 PM
Slow Progression FRS Build dgerny Member's Car Journals 1 04-15-2014 07:48 PM
Tkalz slow build! Tkalz Member's Car Journals 15 10-13-2013 06:35 PM
Slow Build by Jooks jooks Member's Car Journals 4 07-03-2013 11:53 PM
