Drives: Boosted frs
P062d & p0451
So recently I upgraded my turbo kit (headers, intercooler & turbo). After I installed everything I have no pedal response. My engine revs constantly 1k to 2k. The only thing I changed out besides the kit was a02 sensor could that be the cause? Any suggestions would be appreciated.
#2 |
Drives: Crapcan
P062D is either an open or short on the DI injector driver circuit or another fault related to the DI driver or ecu. I would check all connections to the injectors and driver module, and make sure the driver module screws are tight. It ground through it's mounting screws.
P0451 is a difference in the evap canister pressure sensor output and the map sensor output. Check for a damaged hose, or electrical connector for the sensor to the evap canister.
#3 | |
Drives: Boosted frs
| The Following User Says Thank You to Fiend For This Useful Post: | NoHaveMSG (06-13-2021) |
#4 |
Drives: '13 FRS - STX
Omg lifesaver. Thought I had ducked up my injectors, rough running, misfires, wouldn’t hold idle. Ecu wasn’t grounded, bolted it down, problems gone.
Facepalm.jpg |
| Tags |
| 02 sensor, avo turbo kit |
| P0451 | FirestormFRS | Issues | Warranty | Recalls / TSB | 10 | 05-03-2023 12:56 AM |
| Problems related to code: P0451 | Teratorry | Issues | Warranty | Recalls / TSB | 1 | 07-23-2020 02:52 PM |
| P0451, P0451, P0453 Fix? | jaimeFRS | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 04-29-2020 04:01 PM |
| P0451 & U1201 after JRSC installation. | Thepest | Northern California | 1 | 04-06-2020 08:22 PM |
| P062D | Cobiflex | Issues | Warranty | Recalls / TSB | 5 | 09-12-2019 11:49 AM |
