| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Shocks Upgrade
It's been a while since I have started thinking of upgrading the shock absorbers on my 2013 Subaru BRZ Limited. Thinking of checking out Bilstein Shocks. Has anyone tried their B6 Series Shock absorbers?
#2 | |
Drives: 2015 BRZ
https://www.ft86club.com/forums/showthread.php?t=143629 Additionally i have them as well installed with my RCE Yellows and they are an awesome upgrade over the stock shocks. I would say it still rides firm and not jarring and bouncy as the stock shocks. It stays planted throughout corners, hardly any body roll and corner entry and exit definitely allow for much higher speeds than before. Its a worthwhile upgrade. |
#3 |
Drives: '23 BRZ
I have B8s, same as B6 except less droop travel for lower springs (which isn't really necessary to keep springs captured even at 1.25" lower).
Great improvement over the factory PP/Sachs IMO, much smooover ride and I'd bet 20+mm more bump travel (important if lowered). Damping is fine street and track for me with 4.4 front 5.3 rear springs, should be fine for stock springs as well. |
#4 |
Drives: 17 Asphalt 86
I have B6 paired with RCE springs. They're a solid upgrade over stock.
#5 |
Drives: 2017 Toyota 86
#6 |
If you don't want any adjustments you can't go wrong with the Bilstein dampers. Do yourself a favor and grab some RCE Yellows or swift springs.
2013 Series 10 FRS #553
#7 |
Drives: 2019 BRZ Sport-Tech RS
#8 |
FT8Syg
Drives: `12 FRS & `17 BRZ Inazuma
It's worth every penny!It should last about the same as the car itself & may even outlast the other coilovers. Paired with mild-drop lowering springs like RCE Yellow & TRD, the ride is planted, stiff but not harsh yet comfortable unlike stock.
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
#9 |
Drives: Subaru 86
4wheelonline recommends Bilstein shocks. They're selling it for a fair price.
#10 |
Drives: '13 Whiteout
I have the B6’s with H&R springs along with Verus camber plates. The car just feels so solid. Between those things and heavier, adjustable sway bars I have the car to where I want it handling wise. Tires are NT01’s
| FS: OEM Shocks | brzt | Brakes, Suspension, Chassis | 1 | 06-07-2020 04:00 AM |
| Suspension Upgrade 2013 using 2016 shocks? | JonnyQuest264 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 11-17-2016 08:14 PM |
| On lowering springs for and stock shocks, time for new shocks... | Basket Case | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 11-16-2015 08:31 AM |
| Upgrade Shocks - RSR Morimoto spec i sport coilovers vs RCE Tarmac 0/2 | MaXimus | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 05-21-2014 08:46 PM |
