Drives: 2020 toyota 86
Hood Struts
Looking for suggestions..thanks
#2 |
Drives: 2018 Subaru BRZ
86speed.
#3 |
LMGTFY
Drives: 13 FRS, 91 Miata
Home Depot
#4 |
Drives: 17 Asphalt 86
What I run. $50. I don't see the point in spending hundreds on generic struts with a company logo slapped on it.
https://a.aliexpress.com/_mL28UU5 |
#5 |
Drives: -
I never had an issue with the OEM rod, but If you must, Grimmspeed. They’re the only ones that considered reinforcing the hood in bending, since it wasn’t designed to be loaded that way.
| The Following User Says Thank You to Transport3r For This Useful Post: | whataboutbob (06-12-2021) |
#6 |
Drives: '20 BRZ tS (15/300) / '09 Scion tC
I have the GrimSpeed struts. When you install them (or any) I advise installing the left one first if you are doing it yourself. For some reason when I tried installing the right one first I couldn't clear the strut tower without forcing it. If you have an extra set of hands it will also make it easier.
#7 |
Grimmspeed
/thread
| The Following User Says Thank You to Ultramaroon For This Useful Post: | whataboutbob (06-12-2021) |
#8 |
Thanks to all that replied.
#9 |
AutoX-10/10ths every run
| The Following User Says Thank You to whataboutbob For This Useful Post: | Ultramaroon (06-13-2021) |
#10 |
FT8Syg
Drives: `12 FRS & `17 BRZ Inazuma
I recently installed Grimmspeed too & it's a better than the carbon hood dampers I had on my FRS. Grimmspeed allows the hood to let gravity do its job to close it when it's at about 15 deg whereas the carbon one had to pushed all the way down in order to close.
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
#11 |
Drives: 2019 BRZ Sport-Tech RS
I also recently installed the Grimmspeed hood struts and the opening and closing operation is very natural - albeit it opens a bit strong once it reaches the top if I let it go.
Most cheap kits and DIY people just get generic brackets and bolt them up to the closest hole on the hood. It's not that simple. There is actual physics involved and Grimmspeed has done the engineering to calculate the correct angles and loads for their own custom brackets to ensure reliable opening and closing of the hood. Last edited by N_Raged; 06-22-2021 at 09:55 AM. |
| The Following 2 Users Say Thank You to N_Raged For This Useful Post: | Dzmitry (06-22-2021), Ultramaroon (06-22-2021) |
#12 |
Drives: 2017 Toyota 86 (860 SE)
I love my Grimmspeed struts as well. Car should have come with them from the factory.
| The Following 3 Users Say Thank You to Cephas For This Useful Post: |
#13 |
Drives: 2013 Scion FR-S 10
are the grimmspeed ones okay with a CF hood. I will be getting one in a year or so and dont want any mishaps.
#14 |
| The Following User Says Thank You to Cephas For This Useful Post: | Ultramaroon (06-25-2021) |
| Brz Hood Struts | Bluetail | Brakes, Suspension, Chassis | 7 | 07-15-2016 03:44 PM |
| [WTB] Hood Struts | Devante | Want-To-Buy Requests | 0 | 07-12-2016 04:23 PM |
| WTB hood struts | driftking96 | Want-To-Buy Requests | 1 | 05-24-2016 07:33 AM |
| [FS:WA] NEW* Grimmspeed Hood Struts | Koa | Engine, Exhaust, Bolt-Ons | 5 | 04-06-2016 11:51 PM |
