Old 06-07-2021, 07:28 PM   #1
DerJuso
Drives: Gt86 2013
P1235
Hey Guys i am rebuilding an GT86 and now, in the end fase i got some problems. When i start the car it will stay on 1500 U/min. After like 10 sek it will drop to 1000 and raise to 1500 like if i push the gas but i dont. i made a video i hope you know what i mean.
Video:
PS: dont mind the sound it was before i installed the exhaust but with exhaust its the same problem
I got the engine errors: P1235, P062D
Sry for my english i hope you understand me
Thx for your help!
DerJuso is offline   Reply With Quote
Old 06-07-2021, 08:56 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I'd start by checking to make sure the connector going to the DI pump and the DI driver are seated and not damaged. Both of those codes indicate a possible short or open on the DI circuit.
Old 06-08-2021, 04:32 AM   #3
DerJuso
Drives: Gt86 2013
Okay and where/how can i check that? I also forgot to say that i already changed the hpfp. I cleand the connectors while changing it.
Old 06-08-2021, 06:39 AM   #4
steve99
Drives: FT86
Alos check the DI compiter on side of engine has all three mount bolts tight including the hard to get at on at bottom and all conectors on DI computer plugged in all the way
Old 06-08-2021, 07:09 AM   #5
DerJuso
Drives: Gt86 2013
I dont put that on til now just plugged it in. I will try it directly!
2013 scion FRS intermittent p1235 140db86 Issues | Warranty | Recalls / TSB 1 12-08-2020 06:13 PM
P1235.... What should I look for? guybo Issues | Warranty | Recalls / TSB 7 12-14-2018 05:43 PM
P1235 and toyotas solutions Diz86x Issues | Warranty | Recalls / TSB 0 09-23-2017 04:09 PM
CEL P1235 After turbo kit? 86_ZN6 Forced Induction 24 05-02-2016 12:34 AM
