Old 06-01-2021, 06:42 AM   #15
Gt86Force
Drives: GT86 Supercharged
Originally Posted by BrahmaBull1990 View Post
This is really interesting. So your oil looked fine when you drained it? Maybe you could just retorque the heads?
Drained both oil and coolant and everything looks fine, that was the strange thing...
I will rebuild the engine from 0 just to be sure btw, forged internals and stock heads with upgraded springs. The car sees to much track time and it has some miles on the odometer now.
Gt86Force is offline   Reply With Quote
Old 06-01-2021, 06:52 AM   #16
Gt86Force
That wasn’t answering his question. A catch can won’t change the fact that the PCV valve needs upgrading so you don’t pressurize the crankcase. Unless you ran the system open/ventilated to atmosphere, you will be pressurizing the crankcase when on boost.
Oh, okay, now I've understood the question. Sorry but my english is terrible, and some technical things are difficult to understand.
If the radium kit doesn't include upgraded valves, then no, I'm running the stock one. Do you think that was the root cause? I'm not that mechanically inclined, I understand the basic things from a hw/sw point of view (I work in automotive but not the engineering part), but I let specialized shops do the work.
Old 06-01-2021, 07:59 AM   #17
tomm.brz
Drives: brz 2017 hksv2
can be, change it as soon as you can
part number subaru: 11810AA141
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
Gt86Force (06-01-2021), Irace86.2.0 (06-01-2021)
Old 06-01-2021, 10:38 AM   #18
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
The stock PCV isn’t designed for boost, so it will allow positive manifold pressure during boost to not only stop gases from venting out of the PCV, but air will also reverse into the crankcase and pressurize it more.
Signs of this are piston ring damage, lifted oil dipsticks, smoke from the tailpipe, fouled spark plugs, gasket seal failure so oil running down the engine, up to engine failure.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Old 06-02-2021, 02:22 AM   #19
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
I think you are overthinking all off this.
Have you check any of this yet?
KISS
https://www.autozone.com/diy/coolant...ir-to-overflow
Old 06-02-2021, 02:54 PM   #20
Irace86.2.0
KISS
He is thinking this happened. His symptoms might be more specific than just having coolant overflow.
Old 06-02-2021, 06:23 PM   #21
Grady
Grady's Avatar
The head bolts are suppose to be single use. They are torque to yield. This is not good advice.
The 2nd torque after use will literally be torque to yield.
Old 06-02-2021, 07:01 PM   #22
Irace86.2.0
I believe they will need to be measured to see if they are in compliance/spec within the stretch/deformation grace length. Considering someone is running boost with high compression and is having issues and might be dodging a bullet, taking a chance on retorquing and clocking the bolts is risky. If they aren't to spec then they will need to be replaced. Do people reuse TTY headstuds? Yes. I doubt they are reused under warranty work. Just tightening the headstuds is enough of a project that it would be best just to do head studs. I personally would switch to ARP head studs.
BrahmaBull1990 (06-02-2021)
Old 06-02-2021, 11:34 PM   #23
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
“I would say it’s okay advice”
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 06-03-2021, 06:06 PM   #24
Gt86Force
Wow, this is exactly what happened to me. Ok different engines, but looks like my problem.
@x808drifter
I wish it was something trivial like that... but I'm not that lucky, did all the tests ofc and everything was ok. Besides the car worked well for like 2 years, it's not a new build or something, so something happened.
I also don't like the 50/50 solutions like re torquing the heads. Also once disassembled, from my experience, you need to resurface the heads and the block and I want to have a look at the pistons just to be safe. I will rebuild everything just for piece of mind (forged internals, arp studs, upgraded springs etc.).
I don't like it since is quite expensive (I need to ship the car abroad and the labour costs are double from what I've seen in USA) but I plan to keep the car at least another 3 years and in the long run probably it's cheaper.
At this point I hope the heads/short are reusable and not dameged beyond repair bc finding a replacement could be a pta, but I think I'm ok since the car was still running and there was no sign of contamination of oil or coolant.
The Following 2 Users Say Thank You to Gt86Force For This Useful Post:
Irace86.2.0 (06-03-2021), x808drifter (06-04-2021)
Old 06-03-2021, 06:31 PM   #25
Irace86.2.0
If your heads are bad then I have used ones for super cheap. They aren’t 100%. Just offering.
Good idea on the rebuild while you are in there.
I think I have a blown head gasket; what would you do? Timmy_Jones Issues | Warranty | Recalls / TSB 28 11-28-2018 11:34 AM
Toyota 86/ FRS / BRZ Blown Head Gasket Twin-Dragons Scion FR-S / Toyota 86 GT86 General Forum 4 09-02-2018 04:47 PM
Blown head gasket?? sachu Issues | Warranty | Recalls / TSB 14 07-15-2016 02:08 PM
Blown head gasket?? texasbound972 Engine, Exhaust, Transmission 29 05-19-2015 12:09 PM
is my head gasket blown? BrianBlueBRZ Other Vehicles & General Automotive Discussions 4 07-22-2014 10:45 PM
