#15 | |
Drives: GT86 Supercharged
I will rebuild the engine from 0 just to be sure btw, forged internals and stock heads with upgraded springs. The car sees to much track time and it has some miles on the odometer now. |
#16 | |
If the radium kit doesn't include upgraded valves, then no, I'm running the stock one. Do you think that was the root cause? I'm not that mechanically inclined, I understand the basic things from a hw/sw point of view (I work in automotive but not the engineering part), but I let specialized shops do the work. |
#17 |
Drives: brz 2017 hksv2
can be, change it as soon as you can
part number subaru: 11810AA141 |
| The Following 2 Users Say Thank You to tomm.brz For This Useful Post: | Gt86Force (06-01-2021), Irace86.2.0 (06-01-2021) |
#18 | |
Drives: Q5 + BRZ + M796
Signs of this are piston ring damage, lifted oil dipsticks, smoke from the tailpipe, fouled spark plugs, gasket seal failure so oil running down the engine, up to engine failure.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Gt86Force (06-01-2021) |
#19 |
LMGTFY
Drives: 13 FRS, 91 Miata
I think you are overthinking all off this.
Have you check any of this yet? KISS https://www.autozone.com/diy/coolant...ir-to-overflow |
#20 | |
#21 |
#22 |
I believe they will need to be measured to see if they are in compliance/spec within the stretch/deformation grace length. Considering someone is running boost with high compression and is having issues and might be dodging a bullet, taking a chance on retorquing and clocking the bolts is risky. If they aren't to spec then they will need to be replaced. Do people reuse TTY headstuds? Yes. I doubt they are reused under warranty work. Just tightening the headstuds is enough of a project that it would be best just to do head studs. I personally would switch to ARP head studs.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | BrahmaBull1990 (06-02-2021) |
#23 | |
Howdy
Drives: 2020 BRZ PP
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
#24 | |
@x808drifter I wish it was something trivial like that... but I'm not that lucky, did all the tests ofc and everything was ok. Besides the car worked well for like 2 years, it's not a new build or something, so something happened. I also don't like the 50/50 solutions like re torquing the heads. Also once disassembled, from my experience, you need to resurface the heads and the block and I want to have a look at the pistons just to be safe. I will rebuild everything just for piece of mind (forged internals, arp studs, upgraded springs etc.). I don't like it since is quite expensive (I need to ship the car abroad and the labour costs are double from what I've seen in USA) but I plan to keep the car at least another 3 years and in the long run probably it's cheaper. At this point I hope the heads/short are reusable and not dameged beyond repair bc finding a replacement could be a pta, but I think I'm ok since the car was still running and there was no sign of contamination of oil or coolant. |
| The Following 2 Users Say Thank You to Gt86Force For This Useful Post: | Irace86.2.0 (06-03-2021), x808drifter (06-04-2021) |
#25 |
If your heads are bad then I have used ones for super cheap. They aren’t 100%. Just offering.
Good idea on the rebuild while you are in there.
| I think I have a blown head gasket; what would you do? | Timmy_Jones | Issues | Warranty | Recalls / TSB | 28 | 11-28-2018 11:34 AM |
| Toyota 86/ FRS / BRZ Blown Head Gasket | Twin-Dragons | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 09-02-2018 04:47 PM |
| Blown head gasket?? | sachu | Issues | Warranty | Recalls / TSB | 14 | 07-15-2016 02:08 PM |
| Blown head gasket?? | texasbound972 | Engine, Exhaust, Transmission | 29 | 05-19-2015 12:09 PM |
| is my head gasket blown? | BrianBlueBRZ | Other Vehicles & General Automotive Discussions | 4 | 07-22-2014 10:45 PM |
