Drives: BRZ - GReddy Turbo T518z
Engine Rough idle and cursing sometimes
Engine Rough idle and cursing sometimes it is normal some time rough again i check the fuel pressure, map and maf sensor all constant reading but still rough
| The Following User Says Thank You to Khal1d__ For This Useful Post: | humfrz (05-28-2021) |
#2 |
Drives: 2020 Toyota 86 GT 6M
any error codes? what do you mean when you say cursing? i've never heard of an engine dong that.
| The Following User Says Thank You to saltywetman For This Useful Post: | humfrz (05-28-2021) |
#3 |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
must have some pissed off crickets :O
| The Following 4 Users Say Thank You to HKz For This Useful Post: |
#4 | |
![]() As @saltywetman asked: * What is cursing (you or the engine) ? - ![]() * Is the engine throwing any codes? If so, what codes? How many miles/kilometers on the spark plugs? Have you had any previous problems with the coil packs? Come back. |
#5 | |
no there no codes now, before i month it give fuel rail pressure low put nothing now. i have an air fuel ratio gauge it go rich then lean. i change the plugs in about 40K. and no problem with the coils |
#6 |
ProCrastinationConsultant
your car has a turbo? have you talked to your tuner to make sure that nothing with the tune needs to be adjusted?
do you have the datalogs?
| The Following User Says Thank You to soundman98 For This Useful Post: | humfrz (05-28-2021) |
#7 |
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | bcj (05-28-2021), x808drifter (05-28-2021) |
#8 |
Mileage? Coil and spark plug age?
2013 Series 10 FRS #553
| Engine Stalled, Rough Idle And Knocking Noise On Startup | Slade | Issues | Warranty | Recalls / TSB | 49 | 09-28-2020 11:13 AM |
| Rough Idle | DeathToocher | Engine, Exhaust, Transmission | 18 | 03-20-2020 11:45 AM |
| Engine running rich, stumbling, rough idle after motor swap | toyubie | Engine, Exhaust, Transmission | 19 | 04-07-2018 01:11 PM |
| Took my car in for rough idle... | Da Brz | Issues | Warranty | Recalls / TSB | 34 | 10-29-2016 01:57 AM |
| '14 BRZ Ltd. - Rough Idle | leicaboss | BRZ First-Gen (2012+) General Topics | 20 | 05-22-2014 07:40 PM |
