Old 07-24-2012, 04:03 PM   #29
mike2100
mike2100's Avatar
Drives: 23 BRZ
Originally Posted by SkullWorks View Post
OK so we probed around last night, and the throttle isn't limited versus RPM, it seems to be about as direct of a correlation between throttle angle and pedal angle as you can get, no real delay on inputs no real scaling to speak of,
At redline it closes throttle, other than that it does as you ask under the test conditions we exposed it to, So i have to retract all my statements about thinking the Torque dip and throttle limits were inter-related.
Could you throw together a quick graph of the data?
mike2100 is offline   Reply With Quote
Old 07-24-2012, 05:04 PM   #30
SkullWorks
Drives: SSM LT MT BRZ
no graph needed, the only limitation seems to be the rate at which the motors respond, and the slowing ramp near WOT.
Both of these anomalies show up as a radius in an otherwise very square profile. but that is just the nature of the system.
Old 07-28-2012, 01:30 AM   #31
ae86trueno
Drives: AE86, RS200
Hi SkullWorks, thank you. So it does feel like running straight with cable? In Altezza on lower, it restricted to 50% tb even though you max out the pedal, and it always has the lag. Oh by the way the position between brake n accel pedal, are they align the same level? Altezza' accel pedal is located on deeper level, i wish they are same level.
ae86trueno is offline   Reply With Quote
Old 07-28-2012, 01:40 AM   #32
vividracing
vividracing's Avatar
no graph needed, the only limitation seems to be the rate at which the motors respond, and the slowing ramp near WOT..
And that rate is where you can find the gears fail. The plug in part just changes voltage to speed up the motor response. That adds a load to the system and can cause the failures I see on other systems.
vividracing is offline   Reply With Quote
How's the throttle response? SFTiofoso Scion FR-S / Toyota 86 GT86 General Forum 9 08-14-2012 12:50 PM
To those with the auto -any throttle lag or hesitation at low speed? ahausheer Engine, Exhaust, Transmission 22 07-25-2012 06:21 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
Throttle Blip, and other features? ashtray BRZ First-Gen (2012+) — General Topics 39 03-07-2012 11:52 AM
