Old 05-17-2021, 01:58 AM   #1
SPCorBUST
SPCorBUST's Avatar
How can you tell if emissions monitors are enabled with Ecutek ROMs?
Long story short, I need to get a smog done and my readiness monitors don't seem to be on.
I have headers and an Ecutek tune, and when I use Ecutek's tool to look at the readiness (if I remember right, it's accessed via Tools > OBD Readiness Monitors > Oxygen Sensor Monitor) it doesn't look like its ready. There are a couple other oddities but the main ones I'm concerned about are in bold below:
OBD Monitors
- Supported not checked off, but shows ready
--- Heated Catalyst Monitor
--- Secondary Air System Monitor
--- AC Refrigerant Monitor
- Ready not checked off, but shows supported
--- Oxygen Sensor Monitor
Drivecycle Monitors
- Enabled not checked off, but shows ready
- Ready not checked off, but shows enabled
Regarding the Oxygen Sensor Monitor, I thought I was going to see:
- supported, not ready
- not enabled, not ready
Instead, I'm seeing:
- enabled, not ready
Wth? I have headers and haven't been throwing any related codes, I'm also not doing any of those non-fouler mods. Besides that, I was pretty sure (its been a couple years now) that the monitors were off.
I opened up the ROMs and looked at the logging params, but as I recall those are just some default setups (I think the tuner creates the list) and all params can be accessed at any time, its just a thing to look at, it has nothing to do with whether they're enabled or disabled.
I don't think I can run the OBD Readiness Monitors tool unless the ROM is flashed... I have a bunch of ROMs from all of my tunes over the years, that'd be a lot of flashing to find this needle in a haystack...
Is there any way to find out whether monitors are enabled/disabled on tunes quickly and efficiently, without all of the brain washing?
Side note, ignore the DTC, its a Flex Fuel related issue.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 05-17-2021, 03:48 AM   #2
steve99
Drives: FT86
Ecutek tunes dont fool readyness monitors npr does any tiune system i know of fool readyness or alter them.
If you disable a DTC code in a tune to stop a cel light it doewnt set the readyness to good it jist stops cel code.
Often disavling the cel may prevent readyness from ever passing.
Flex fuel kits generally hijack the evap pressure inpit or the rear 02 senspr input ant therefore will stop readiness monitors from completing and getting to pass
https://www.ft86club.com/forums/showthread.php?t=140955
Old 06-04-2021, 02:06 PM   #3
yEEt42069
Drives: 2018 Subaru BRZ
When I was on OFT, it was able to fool readiness. I passed smog with the tune and catless headers. The smog stations only check by obd in my state. I hope I don't have an issue with Ecutek because I just switched over.
yEEt42069 is offline   Reply With Quote
VVT Not Enabled DarkPira7e Issues | Warranty | Recalls / TSB 87 03-22-2021 01:59 PM
OBD2 emissions monitor via Ecutek haute Issues | Warranty | Recalls / TSB 0 11-25-2019 10:48 PM
Is it possible for ecutek to force ready a monitor for emissions? kev0 Software Tuning 4 08-14-2019 06:40 PM
Ecutek older roms Agent_D Software Tuning 32 05-02-2016 07:55 PM
I need help please, I don't see any roms on my ecutek Frsexxxy Engine, Exhaust, Transmission 2 04-26-2013 01:03 PM
