Old 05-13-2021, 03:50 PM   #1
RWD fun
Passenger seat belt warning too sensitive?
My passenger seat belt alarm will go off for just about anything left in the seat. Head pones even. It drives me crazy. Would it be dumb to disable it? Can I close the seat belt circuit or is there another option?
RWD fun is offline   Reply With Quote
Old 05-13-2021, 04:03 PM   #2
Ashikabi
Ashikabi's Avatar
If your car is loud enough you can't hear it lol. But might be unwise. If your airbags deployed, it'll deploy that one also because it thinks they're is a person there, which would increase the cost of repair. But then again, if your airbags deployed, it's probably a total loss anyways so probably won't matter. I know it can be bypassed but I don't personally know how
Sent from my ONEPLUS A5010 using Tapatalk
Old 05-13-2021, 04:04 PM   #3
You could just keep the seat belt buckled but this would cause the airbag to go off unnecessarily in a crash, which is probably the least of your worries.
Old 05-13-2021, 04:05 PM   #4
Don't put electronic or "moist" items on the seat and it won't go off.
To: Service Managers, Service Advisors
From: Subaru of America, Inc., Fixed Operations Training and Recognition Department
Date: August 1, 2012
Subj: Important information regarding the Occupant Detection System (ODS) on
Impreza and BRZ
Federal Motor Vehicle Safety Standards, require the use of an Occupant Detection System (ODS). This
system is designed to determine if a person is seated in the
front passenger seat
, and more importantly, if
the person is of adequate size to be protected in the event of the deployment of the front passenger seat
airbag (SRS) in a moderate to severe frontal collision.
Most Occupant Detection Systems measure the weight of the front seat passenger, to determine if the
front passenger seat airbag should deploy.
All 2012 and 2013 Impreza and 2013 BRZ models use a new type of Occupant Detection System called
Electrostatic Capacitance Sensor ODS. This system does not use weight to determine whether to turn the
Occupant Detection System ON and OFF. It is important that you understand the operation of this system
so that you can explain its operation and precautions to your customers.
Electrostatic Capacitance Sensor ODS uses electrostatic capacitance to determine passenger airbag
status. Electrostatic capacitance represents a material’s capability of storing an electrical charge. Have
you ever been shocked when walking across a carpeted floor and touching a door knob? This
demonstrates your ability to store an electrical charge in your body.
When anyone is seated or when anything is placed on the front passenger seat, there is a change to that
capacitance value. This change in capacitance value is what the Electrostatic Capacitance Sensor ODS
uses to determine whether the front passenger seat airbag (SRS) will be ON or OFF.
Everything that is placed on the seat has the potential to affect a change in capacitance value. The
system can determine whether to change the OFF status of an airbag to ON depending on what is on the
passenger seat, which in turn causes a change in capacitance value.
Some examples:
 A proper sized passenger will change the OFF status of an airbag to ON
 Plastic, metals and other substances, even if at a heavy weight, will not change the OFF status of an
airbag
 A false electrical charge, for example, those caused by laptops that are processing data, cellphones
that are on or even an electric device connected to a car charger can cause the airbag status to
switch to ON
 When water or anything with high moisture content is spilled on the front passenger seat cushion, the
airbag is designed to remain OFF until the seat cushion is dry. This will also be the case if the
passenger has moisture on their clothing, such as rain-soaked pants or raingear. In each of these
situations, the airbag status may remain OFF even if a passenger is seated.
Subject information for customers:
 “The Electrostatic Capacitance Sensor ODS on 2012 and 2013 Impreza and 2013 BRZ models uses
an electric charge to determine what is on the front passenger seat. (To assure the customer that
they will not get shocked, use the static electricity and touching the door knob example)
 Advise the passenger not to sit in the front passenger seat if the seat cushion is wet or if their clothing
is wet.
 The best way to ensure proper operation is to keep everything off the front passenger seat except a
passenger
 For more detailed information, stress to your customer the importance of reading and understanding
the Owner Manual
By reading the Owner Manual, your understanding of how this system functions directly affects how
confidently you will be able to discuss this ODS system to your customers. For more detailed information
on this and other types of Occupant Detection systems used in other model year Subaru vehicles, please
click on this link to register and attend a web based technical overview: technician training video.
*Passengers seated in the front of the vehicle must meet all State and Federal regulations according to
Federal Motor Vehicle Safety Standard 208. Never install a child seat or booster seat in the front of the
vehicle. See Owner Manual for more detail.
Cc: DPSMs, RSOM
Dadhawk (05-13-2021), humfrz (05-13-2021)
Old 05-13-2021, 04:29 PM   #5
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Like Tcoat stated, don't put any electronic or don't get it wet.
If it bugs you that much, get one of these
The Following 2 Users Say Thank You to ichitaka05 For This Useful Post:
humfrz (05-13-2021), Tcoat (05-13-2021)
Old 05-13-2021, 09:53 PM   #6
passenger
The Bubba edit -
Ultramaroon (05-14-2021)
Old 05-13-2021, 09:54 PM   #7
......and those are?
(some sort of sex toys?)
Old 05-13-2021, 09:57 PM   #8
ichitaka05
Site Moderator
ichitaka05's Avatar
Car seat belt clips
humfrz (05-14-2021)
Old 05-14-2021, 03:15 AM   #9
Impreza and BRZ
Some examples:
airbag
switch to ON
is wet.
passenger
the Owner Manual
Cc: DPSMs, RSOM
Man, that's a lotta words.
humfrz (05-14-2021)
Old 05-14-2021, 08:47 AM   #10
That is why it is a copy and paste from Subaru.
Hum gave the best summary.
humfrz (05-14-2021)
Old 05-14-2021, 09:08 AM   #11
Never have quite understood the point of these, since you can just plug in the seat belt.
Old 05-14-2021, 09:14 AM   #12
Ashikabi
Ashikabi's Avatar
Other than it's ugly... There isn't a point. I guess you could sit in the seat before unbuckling instead of leaning in to unbuckle first if there was a passenger.
The Following User Says Thank You to Ashikabi For This Useful Post:
Dadhawk (05-14-2021)
Old 05-14-2021, 10:50 AM   #13
ichitaka05
Site Moderator
ichitaka05's Avatar
Both make good points. For me, it’s all about the visual look. I have prego extend seat belt for my aftermarket seats. Yes, you can clip seat belt in, but visually it doesn’t look good imo. I went to countless car meet & every time I see that, it looks so weird & out of the place. I get why they do it, but so ugly.
Old 05-14-2021, 11:01 AM   #14
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
You can turn the alarm off.
Either through asking the dealer to do it through techstream or doing it yourself with something like the carista dongle.
Dongle lol.
Happy Friday!
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following User Says Thank You to Wally86 For This Useful Post:
How does (very sensitive) passenger seat seat belt sensor work? GrantedTaken Cosmetic Modification (Interior/Exterior/Lighting) 23 10-03-2018 01:43 PM
Passenger Seat Belt Warning Chime goes on even though there's no passenger. idreamofdrifting Issues | Warranty | Recalls / TSB 58 10-11-2017 11:31 AM
Sensitive Passenger seat??? Trmx2 Scion FR-S / Toyota 86 GT86 General Forum 5 01-07-2014 08:35 PM
Passenger seat belt warning when I put phone on seat!??? Kayzer Soze BRZ First-Gen (2012+) — General Topics 20 09-13-2013 12:29 PM
Passenger side seat belt frs-guy Issues | Warranty | Recalls / TSB 1 10-11-2012 01:39 AM
