#113 | |
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | timurrrr (04-29-2021) |
#114 | |
Okay I’m not familiar with blackjack or HUDer and a quick Google turns up nothing for either of them. Do you have any links? |
#115 |
Drives: Planning for GR86
Here accuracy panels: 10% faster
But it’s not a problem. Your circuit references are based on your speedo. And legal road limits are based on this wanted poor accuracy. |
#116 |
Digital is fine, no issues in 5 years of ownership. Only looked at the needle speedo once and it’s too small. You are way overthinking this.
#117 | |
They're talking about the digital speedo and their superhuman ability to notice that it might be a quarter second off of where it should be while negotiating the Forrest Elbow at Mount Panorama.
![]() Semi-serious though Timurr, I get what you're saying. You're saying it doesn't matter so much that the speedo is inaccurate, just that it should be consistently inaccurate. But let's look more closely at your example from the last page: Quote:
So T6 at MLC... you've entered, headed for the apex, and you've picked up your exit point, your eyes are now looking up the hill to get the car in position for the corkscrew. That's where you should be looking. Looking at the speedo in any of those instances is taking your eyes away from where they should be. Furthermore, you should be able to tell whether you're on speed because you either hit your targets or you don't. You're either in the power band, or you're not (that's why the tach is the right in the center of our display). Your eyes should be outside the whole time at most every point on that track aside from maybe the front straight when you're just WOT and heading for the line. I will bet you'd see better overall time gains if you put a piece of cardboard over the instruments, drove outside the whole time and just focused on hitting your entry/apex/exit every turn through feel and engine sound, than you'll ever gain from worrying about 1 mph (+/- .025 seconds) at any given point along the track. Last edited by Dake; 04-30-2021 at 02:04 PM. |
| The Following User Says Thank You to Dake For This Useful Post: | soundman98 (05-01-2021) |
#118 | ||||||
Drives: 2022 GR86
The timing is as precise as any reference people use for braking. Quote:
But just the second thoughts that I don't know if the speed I'm looking at, when I do look at it, makes me doubt the speedo. Quote:
It's more of a sampled data check as I go, primarily used to sanity-check/calibrate my seat of pants. Looking and thinking ahead is still the priority, of course. Quote:
Not theoretical, but happens every time when you're "on it", affects all speedometers of all cars, and easily affects the reading by up to 5 mph when driving on the track. Curious when someone brings it up ![]() But again, a fairly consistent/predictable/correctable one. |
#119 |
What about a Nixie Clock? These are pretty sweet, retro but fast.
https://eshop.3dsimo.com/collections...c13nXZoAUAJieE You can crank some of these puppies up to like 100,000hz! https://hackaday.com/2019/12/12/cust...-100000-hertz/ Sent from my SM-G975U using Tapatalk |
#120 |
Drives: Subaru
A car with a digital speedometer uses a speed sensor, which usually consists of a magnet surrounded by a wire coil, quite like the pickup on an electric guitar. The sensor is mounted directly next to a gear on the transmission, and as the gear spins, its teeth whiz by, interrupting the magnetic field on the sensor.
Nobody loves slow speed refresh,this may occur due to faults the speedometer should try to show exact speed.
#121 |
Drives: WR Blue Pearl 2022 Subaru BRZ
It will be predictable.
You also have revs and gear you are in displayed without the same keep and hold as the speed, and these have an much more optimal layout for racing as per the new visual mode. It should be one of the better cars for track day information. |
#122 |
ProCrastinationConsultant
i don't think i've ever heard of people at track days talking about their speed through corners. it's usually references to rpm and/or gear selection. 'should be topping out 3rd there, but instead of shifting, hold to redline, that'll be the braking zone point for the next turn'...
#123 |
I too wonder about the value of a speedo on the track. Several of my track cars had NO speedo. Reviewing telemetry after a race or practice run was instructive but not while driving. Too much else going on to be looking at a speedo.
| The Following 3 Users Say Thank You to ls1ac For This Useful Post: |
#124 |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
OP is professional driver from italy.
#125 |
Nope, I’m just a software analyst in love with cars and technologies.
But you must to be a pro comedian, thank you for your contribution.
| The Following User Says Thank You to Kronk For This Useful Post: | HKz (05-04-2021) |
#126 |
Drives: 2022 GR86
| In-dash digital speedometer | vaer | Electronics | Audio | NAV | Infotainment | 4 | 04-14-2020 11:19 AM |
| Does the BRZ get same refresh? | snezze21 | BRZ First-Gen (2012+) — General Topics | 74 | 03-24-2016 02:51 PM |
| Convert the digital speedometer from Kmh to MPH? | Jastation | Electronics | Audio | NAV | Infotainment | 10 | 09-28-2015 06:46 AM |
| Digital speedometer in base GT86? | rhysmcinerney | Electronics | Audio | NAV | Infotainment | 25 | 01-22-2014 07:18 PM |
| Fast car Fast driver vinyl decal I need help | francosolracer | Cosmetic Modification (Interior/Exterior/Lighting) | 18 | 10-20-2012 04:43 AM |
