Old 04-09-2021, 03:49 PM   #15
I PM’d him offering help, so he might.
He hasn't logged on since slamming the forum for not being nice enough to him.
Old 04-09-2021, 04:07 PM   #16
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I know, which is why I PM'd him because that should send him an email notification.
Old 04-18-2021, 05:18 AM   #17
FRS_FIEND
Whats next?
FRS_FIEND's Avatar
Drives: '13 Asphalt FRS MT
[QUOTE=tomm.brz;3421330]i haven t understood why OP is looking at the value if atmosferic pressure to see the boost..
Atmosferic pression is atmosferic pression and nothing else
Did the tuner say to you he relocated somehow the value of atmosferi presure to show the Manifold Relative Pressure?
when reading on atmospheric pressure I misunderstood it.
Life is too short to drive a boring car...
Instagram: @angelb_af
FRS_FIEND is offline   Reply With Quote
Old 04-18-2021, 05:21 AM   #18
FRS_FIEND
Whats next?
FRS_FIEND's Avatar
Don't think he is coming back!
"He hasn't logged on since slamming the forum for not being nice enough to him."
I said some people in this community. I did not say the entire forum. the reason why I haven't logged in is because my wife and I had another son so I've been focusing on taking care of my family. I do not go on the internet often either, nice try on the assumption though.
The Following User Says Thank You to FRS_FIEND For This Useful Post:
Irace86.2.0 (04-18-2021)
Old 04-18-2021, 05:35 AM   #19
FRS_FIEND
Whats next?
FRS_FIEND's Avatar
He might be confused or stating things wrong. Hopefully he isn’t confusing atmospheric pressure with absolute pressure.
Atmospheric pressure should be 1 bar or 14.7 psi, or it should be less if he lives at altitude, so Reno/Tahoe might be 12.5-13 psi. A turbocharged car will still hit wastegate pressure under load, but it will just take longer at altitude, so his absolute pressure should be the same anywhere. With that said, the delta will be higher, meaning, it will take 1-1.5 more psi of turbo pressure to get to wastegate pressure because there is 1-1.5 less psi of atmospheric pressure. This would lead to more heat and less efficiency.
Hopefully he isn’t confusing atmospheric pressure and absolute pressure. Absolute pressure should be atmospheric pressure + boost pressure, so hopefully he doesn’t look at that larger number and freak out even more, thinking it is solely his boost pressure.
I did confuse the two, what freaked me out was the tuner saying my wastegate spring is too tight and that he set my boost cut to 15psi. My car was tuned in 66ft above sea level. I live 2700ft above. i checked boost solenoid routing and it is routed properly.
thanks for the helpful posts, much appreciated
make me less dumb - how tight is too tight for brake pads? slowmow Tracking / Autocross / HPDE / Drifting 9 11-03-2020 10:32 AM
Clicking when turning tight Impureclient Issues | Warranty | Recalls / TSB 7 06-23-2020 06:36 AM
17x8+45 with 8.3” tread width tires = tight spring perch to tire clearance Chuckable Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 06-03-2019 02:09 PM
Oi Takashi in USA, driving for Import Tuner Magazine FRS tuner impressions. Moto-P Scion FR-S / Toyota 86 GT86 General Forum 15 11-19-2015 05:39 PM
Fuel Lid Tight or Loose? JiB Issues | Warranty | Recalls / TSB 18 09-20-2012 01:50 PM
