| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives:
Tpyota 86 AT 2013 oil consumption, pls help
My car is NA and bone stock at the moment. Will install eforce after my motec problem is done.
But my oil consumption is pretty high. 1000km for half liter/ 500cc Is there anyone who got this problem too? I am using 15w50 motys m110 Should i use 5w30 ? Please advice. |
#2 | |
Drives: 2018 Subaru BRZ Limited with PP
#3 |
Drives: 2017 toyota 86
Maybe running too thick oil has caused excessive wear causing greater oil consumption.
Factory spec is 0w-20, unless you think you know something the engineers who designed the engine don’t. I’d suggest sticking to factory recommended oil weight. |
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | alphasaur (04-09-2021) |
#4 | |
Drives: -
Factory spec is 0W-20 in the us, but 5w-30 in some countries. It’s mostly a recommendation for fuel economy, you’ll see significantly higher metal wear with 20 weight oil vs a similar 30 weight. STI recommends 5w-40 for Tracking IIRC. I wouldn’t run 50 weight in a DD FA20, but I prefer a 0-W30 over a 0W-20. |
| The Following User Says Thank You to Transport3r For This Useful Post: | Hoahao (04-01-2021) |
#5 |
I’ll stick to manufacturers recommended weight
| The Following 3 Users Say Thank You to 86TOYO2k17 For This Useful Post: |
#6 | |
Drives:
5w30 ? Since i will be running force inductions |
#7 |
Drives:
Yeah thanks. I will try to move back to spec and will report on this forum again
#8 | |
Drives:
I will run 5w30 thrm to meet in the middle. Will 5w30 sufficent for my force induction later |
#9 | |
The only time you should go up a weight is if you have oil overheating problems and then it should be a temporary band aid until you get a proper oil cooling solution. In extreme circumstances no amount of cooling can keep up so you may go up a weight. The idea heavier weight oil is somehow always inherently better is foolish. If so then why stop at 5w30? Why not 10w40 or 30w70? What makes 5w30 the magic weight? Heavier is better right, so put some 70w90 in. But wait so then what makes 0w-20 the magic number you ask? The engineers who speced, designed, built, and tested the engine determined it to be the ideal weight. So unless you know something an entire team of highly trained, skilled, knowledge expert engineers who built the engine don’t. Why wouldn’t you stick to the recommended weight oil? Also keep in mind especially for a daily most engine wear happens at initial cold startup, where 0w-20 is far superior. |
| The Following 5 Users Say Thank You to 86TOYO2k17 For This Useful Post: | alphasaur (04-09-2021), Dzmitry (03-31-2021), Maritime Storm (08-27-2022), mrjj (04-02-2021), Tcoat (03-31-2021) |
#10 | |
The oil you are running is extremely thick and probably doing more damage than good on a daily car as it is still too thick at normal operating temperatures. Once you go forced induction, you can start looking into running thicker oils. From there, it will simply depend on your oil pressure, which I would recommend getting a gauge for. Now if you consider tracking or doing any intense drive when under forced induction, you may also want to consider an oil cooler, but that will be your choice to make. As oil temperatures begin to rise higher than usual (above 230F about), at the minimum you should change your oil to a higher oil weight like 5w-30/40, etc. But at no point should you really ever need 15w-50. It's just not designed for this engine, and if you truly need it to upkeep with temperatures, then you probably should be getting an oil cooler instead. EDIT: One thing I'd like to add is, get back to us on how things are once you move back down to a low weight oil. I am curious if this problem continues now that you have already ran such a high oil weight for some time, but hopefully not of course. Worst case scenario, is you'll have to keep an eye on your oil and topping it off all the time to not create further problems. |
#11 | |
Drives:
And back to your guys |
| The Following User Says Thank You to pro_turbo For This Useful Post: | Tcoat (03-31-2021) |
#12 |
#14 |
Drives: 17 Asphalt 86
Non American user manuals had 5w30 mentioned as an option. I recall the Japanese manual even mentioning something up to the effect of a 5w40 under heavy load conditions (racing)
https://www.ft86club.com/forums/showthread.php?t=105134 Edit: post 3 https://www.ft86club.com/forums/showthread.php?t=131389 |
| The Following 2 Users Say Thank You to RToyo86 For This Useful Post: | Dzmitry (03-31-2021), Transport3r (03-31-2021) |
| 2013 BRZ oil consumption | Project N64 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 32 | 01-16-2020 06:56 PM |
| Oil Consumption? | smbstyle | Tracking / Autocross / HPDE / Drifting | 42 | 10-08-2019 05:50 PM |
| Oil consumption? Please chime in | OnTheFence | Issues | Warranty | Recalls / TSB | 48 | 10-01-2019 09:42 PM |
| E-85 consumption | Lunatic | Tracking / Autocross / HPDE / Drifting | 16 | 01-28-2016 09:15 PM |
| 86 / BRZ Oil Consumption | ZZT86 | AUSTRALIA | 1 | 04-29-2013 09:53 PM |
