#29 |
Drives: 13 BRZ
Finished up the PDM wiring this weekend. PDM is controlling the radiator fans, motec ECU, coils, lambda controllers, and reverse lockout solenoid. Some sensors, gps module, and dash control buttons wired into it as well. It’s also taking data from two can buses. On the CAN1 bus I have the Motec and the factory Subaru bus. On CAN2 I have the two AEM lambda controllers and MSEL battery relay. Will be adding the Aim RIO02 module to that bus too when it’s finally released.
![]() Really happy with how the dash looks assembled. ![]() Still need to wire the fuel level sensor, mount the gps antenna, and figure out the can messages for some of the dash indicators. Half tempted to just take those in as analog signals though. Was trying to learn how to sniff can messages but I didn’t get very far. If you look closely you can see the M130 peaking through. Ethernet connection is for the ECU.
#30 |
Drives: 13 BRZ
Finally started doing the actual swap!
![]() Going in/out from the bottom. ![]() ![]() ![]() Sent from my iPhone using Tapatalk |
| The Following 2 Users Say Thank You to kask2_6.0 For This Useful Post: | Irace86.2.0 (03-30-2021), Swassofrass (03-10-2021) |
#31 |
Drives: 13 BRZ
![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk |
| The Following 4 Users Say Thank You to kask2_6.0 For This Useful Post: |
#32 |
Drives: 13 BRZ
![]() Master cylinder mount courtesy of @spitsnaugle ![]() ![]() Decided to use a fuel manifold fed by the two factory 5/16” hoses. Also has the fuel pressure sensor and 6an feed to the factory ls3 fuel rail ![]() Sent from my iPhone using Tapatalk Last edited by kask2_6.0; 03-10-2021 at 01:05 AM. |
| The Following 3 Users Say Thank You to kask2_6.0 For This Useful Post: |
#33 |
Drives: 13 BRZ
Needed a new project... LS3 soon!
I’ve made a lot of progress the past couple of weekends.
![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk Last edited by kask2_6.0; 03-16-2021 at 02:55 AM. |
| The Following 2 Users Say Thank You to kask2_6.0 For This Useful Post: | Dadhawk (03-16-2021), Irace86.2.0 (03-17-2021) |
#34 |
Drives: 13 BRZ
I’ve been doing my best to document as I go but sometimes I get on a roll and forget to take pics of the process.
![]() ![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk |
#35 |
Drives: 13 BRZ
A lot of fab work this past weekend. Getting pretty close now!
Shift hole block off plate for using the Joe’s racing shifter boot. Factory console and shifter boot will go over this but this will keep the road debris out of the cabin. ![]() Reversed the inlet/outlet on my verus radiator for cleaner plumbing with the LS ![]() ![]() I had a lot of scrap cuts trying to make the y pipe work out just right. Pipe fitting definitely takes a lot of patience and practice. It’s something I will need to do a lot more of to be good at. Took me forever but the end result is decent. ![]() Going to reuse the back half of my old exhaust. The cat will come out but behind that will stay the same. Only a few more pieces to go. ![]() Sent from my iPhone using Tapatalk |
#36 |
wow is all I can say!
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | kask2_6.0 (03-25-2021) |
#37 |
Drives: 13 BRZ
Thanks! I made some more progress on the exhaust last night. I just need to add the O2 bungs and finish welding a couple seems. I’m using a Burns Stainless 3”IDx4.5”ODx27” race muffler in the tunnel and a vibrant muffler out back. Can’t wait to hear it! ![]() Sent from my iPhone using Tapatalk |
#38 | |
#39 |
Drives: 13 BRZ
| The Following 5 Users Say Thank You to kask2_6.0 For This Useful Post: | Dzmitry (03-29-2021), ILLSMOQ (03-30-2021), Irace86.2.0 (03-30-2021), Mike_ZN6 (03-30-2021), Wally86 (03-29-2021) |
#40 |
What does the cross beam look like that holds up the bumper?
#41 |
Drives: 14 BSP Edelbrock BRZ
So you're in Cali, how does one go about handling the emissions stuff with an engine swap like this? I don't see cats anywhere.
#42 |
Drives: 2017 WR BLUE BRZ
| What is needed for | Aluma007 | Engine, Exhaust, Transmission | 9 | 11-25-2018 03:20 PM |
| Electric Power Steering Adjustment Project - Help Needed | brillo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 12-07-2015 08:34 PM |
| Logged Track Time Datasets Needed for my Web Project! :) | Zamyatin | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-11-2015 02:59 PM |
| HELP NEEDED!!!! | sklimo | Issues | Warranty | Recalls / TSB | 26 | 06-14-2013 12:48 PM |
| MOD's Needed. Help Please! | GT-ROKIN | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 10-06-2012 02:18 AM |
