Old 02-11-2021, 11:04 PM   #29
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
Originally Posted by sharpsicle View Post
Mine is a limited BRZ with keyless. Does not function like this at all. Nor would I expect it to. No settings have been changed since dealer delivery. If I exit the car and touch nothing and walk away, it will not lock by itself. Also, "unlocking" on it's own is not what's happening either. It's unlocking based on a proximity sensor in the handle that senses your hand in conjunction with the FOB in range. That same prox sensor will lock the car for you if you hold your hand by the handle before you walk away.
This all requires interaction, though, and is not automatic. The range of the FOB alone does nothing for any of this.
The delayed re-lock if I don't open the door after hitting unlock on the FOB occurs though. That's totally expected and normal. It's a safety mechanism for accidental FOB button pushes.
You are right there is probably something subtle I am doing as I exit the car. I found in the manual about the beeping when drying the car and the relock after an unlock. No mention of fob proximity locking the car. I really need to consciously lock the car now as I never have before.
2020BRZtS is offline   Reply With Quote
Old 02-22-2021, 07:00 PM   #30
tomm.brz
Drives: brz 2017 hksv2
Originally Posted by gpvecchi View Post
As EU cars can't have the lock/unlock beep by law, it can't be enabled, so I'm planning to replace the ECM in my EU model with the JDM one; I checked the electrical wiring, all the same. The ECM is the same in LHD and RHD, so this is not an issue. I already have the JDM ECU calibration, so not an issue.
What do you think? The airbag electronic is different, as Japanese cars don't have the option to disable passenger airbag...
IDK about the keys (mine has keyless entry, one friend replaced the ECM with a used one and didn't have to pair the keys)...
steve99 said ECMs are identical in all car all over the world, manual or auto is the same, just different calibration rom
Those things are under other ECUs and not on ECM and you won t achieve anything swapping it with a JDM ECM
Old 03-06-2021, 02:04 PM   #31
gpvecchi
gpvecchi's Avatar
OK, I replaced the body computer with the JDM one, now I have the lock/unlock beep (that can be enabled or disabled).
Other differences from the EU model: follow me home function is no more present, there's an option to slow down the headlight ignition when set to auto, and there's another annoying thing, a repeating beep when put in reverse, that can't be disabled. Something like the one in trucks, but inside the car.
This would be funny if I'd not have reverse sensors...
Oh, now there's an option that can be enabled in Security tab, but I don't know what it is...
Old 03-06-2021, 07:47 PM   #32
pope
has a funny hat
Drives: 2014 BRZ Limited
if your “new" option in the security tab is an alarm, it'll honk and flash the lights if the doors et al. are opened without using the remote to unlock it after being locked with the remote.
To test: lock with remote, unlock with key, open door, all hell breaks loose.
I forgot I had enabled this setting before putting my car away for the winter and for some reason I locked the doors (habit probably). Then, I removed the battery from the fob to avoid broadcasting the signal all winter for no reason (also, there had been someone signal jacking fobs and steeling cars in the area). A week later I realized my sunglasses and phone charger were still in the BRZ so I unlocked it with the key and couldn't hear anything for a few days after being in a closed garage with a blaring horn (mild exaggeration, but it was loud). Touching the fob to the start button killed the noise.
pope is offline   Reply With Quote
The Following User Says Thank You to pope For This Useful Post:
gpvecchi (03-07-2021)
Old 03-07-2021, 04:58 AM   #33
gpvecchi
gpvecchi's Avatar
Just checked, it doesn't act as you said in mine, the only differences I found enabling that security function is the the security led in the dash is fixed and not blinking, and that internal unlock button is disabled.
May somebody please tell me if US cars have this features and if they can be enabled/disabled?
Lock unlock beeps
Follow me home
Reverse beeping
Thanks!
Old 03-07-2021, 11:21 AM   #34
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
Lock unlock beeps
Follow me home
Reverse beeping
Thanks!
On my USDM default factory settings:
Lock unlock beeps - Yes
Follow me home - Yes
Reverse beeping - No
But you said you got a JDM module, not US right?
sharpsicle is offline   Reply With Quote
The Following User Says Thank You to sharpsicle For This Useful Post:
gpvecchi (03-08-2021)
Old 03-07-2021, 10:33 PM   #35
Compelica
Compelica's Avatar
Drives: 86 GT
@gpvecchi just caught up here... relating to your question mine only has a single long beep when placed into reverse, but will not beep after or like a reverse sensor. Mine has no reverse sensors by the way.
edit: beeps do go on and on in reverse, even without reverse sensors
Compelica is offline   Reply With Quote
The Following User Says Thank You to Compelica For This Useful Post:
Old 03-08-2021, 01:53 AM   #36
gpvecchi
gpvecchi's Avatar
I'm thinking of getting the US version now...
Exactly my issue, it beeps like reverse sensor, and I have them! Now it's a mess of beeps...
Old 03-08-2021, 05:03 AM   #37
Compelica
Compelica's Avatar
Drives: 86 GT
@gpvecchi I have made a mistake - the car does go on beeping when on reverse. I got confused with another car of mine :/
Old 03-08-2021, 06:17 AM   #38
Thefalls
Thefalls's Avatar
Drives: Corolla GT
JDM Facelifted MT
Reverse Beep - yes
Lock/Unlock Beep - yes
Follow Me Home - no
I agree the reverse beep is a nightmare. But it did save me once or twice. Since the reverse is next to first gear it saved me from launching forward when i was in a rush.
PS: Its my first car with reverse next to first gear ��
But Im used to it now. ��
Thefalls is offline   Reply With Quote
The Following User Says Thank You to Thefalls For This Useful Post:
Wally86 (03-08-2021)
Old 03-08-2021, 04:45 PM   #39
gpvecchi
gpvecchi's Avatar
The beep in reverse in not annoying, it's not noisy. The issue is that I have reverse sensor, and it becomes an orgy of beeps...
Edit: I can't buy the US unit, or my A/C will switch to Fahreneit...
Old 03-09-2021, 09:59 AM   #40
sharpsicle
sharpsicle's Avatar
What was wrong with keeping it EU? It seems like that's the closest fit for what you want. Sure, it doesn't have the lock/unlock beep, but everything else is correct.
Old 03-09-2021, 05:22 PM   #41
gpvecchi
gpvecchi's Avatar
Those beeps...
Oh, and it adds alarm, EU models don't have alarm enabled.
I managed to enable it with the procedure found on this forum, the EU computer doesn't have it.
Now I'm planning to convert reverse sensor to visual notification.
Old 03-12-2021, 01:50 PM   #42
Compelica
Compelica's Avatar
Drives: 86 GT
How does the follow me home function work for the EU BCM modules?
Vehicle Finder Setting for the BRZ using Toyota Techstream AnthonyArcaro Software Tuning 0 02-29-2016 01:43 PM
Modding squirrel finder wbradley Cosmetic Modification (Interior/Exterior/Lighting) 6 07-10-2013 03:53 AM
Help! Squirrel finder issue! Jacob G. Cosmetic Modification (Interior/Exterior/Lighting) 13 03-01-2013 02:26 PM
Car Finder feature on Remote eriktherod Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 08:23 AM
