Old 02-26-2021, 08:16 PM   #15
Grady
Grady's Avatar
Pull the engine out and fix it.
Also when you have the engine out you may want to install your top-hats correct. Not sure what ones you have but they appear to be clocked wrong.
Old 02-26-2021, 10:06 PM   #16
Ashikabi
Ashikabi's Avatar
Just saw someone on facebook selling a 2016 motor for 3400$
Sent from my ONEPLUS A5010 using Tapatalk
Old 02-26-2021, 11:15 PM   #17
itsAlex
itsAlex's Avatar
Drives: 2016 4Runner / 2016 FR-S
That sounds more like a sound coming from the valve train to me -
Anyway, if it's NOT the HPFP making that sound, it ain't good -
I think I've already accepted the fact that it's toast at this point... Now I'm looking around for used FA20s in case I need to source one... Haven't found any
I'm pretty sure you can't see the top hats in the video I posted... I think you may be confusing my video with the Youtube video I linked in my first post? As for pulling the engine out, it's inevitable. Time to roll up the sleeves I guess
I pay more per month for insurance than I pay for the FRS.
itsAlex is offline   Reply With Quote
Old 02-26-2021, 11:39 PM   #18
Decep
Drives: 2013 FR-S Series 10
Damn valve spring recall makes it harder to find engines huh?
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 02-27-2021, 08:33 AM   #19
The Red One
Pro Couch surfer
The Red One's Avatar
Drives: 2019 BRZ Sport-tech RS.City car:GD3
Originally Posted by Decep View Post
You don't know he's lugging it.
Just a conclusion from Op’s info about where he has his Shift light set quite low, If he is actually shifting at that point places the next gear quite low… Gearing 101!
The Red One is offline   Reply With Quote
The Following User Says Thank You to The Red One For This Useful Post:
NoHaveMSG (02-27-2021)
Old 02-27-2021, 03:42 PM   #20
Decep
I shift at 2500 rpm when the engine is cold with no lugging. At least in the first couple gears. It's not just RPM its load.
Anywho the OP ended up saying 3900 rpm.
Good lesson to be learned here, enjoy things rather than try to preserve em. I remember my old plasma TV i would keep the brightness down to half to keep things from burning in. And one day the motherboard fried randomly. Shoulda just enjoyed it while it was good.
RCE SS-1 Coilovers
Corsa Catback
The Following 2 Users Say Thank You to Decep For This Useful Post:
Icecreamtruk (03-02-2021), The Red One (02-28-2021)
Old 02-27-2021, 06:42 PM   #21
Ashikabi
Ashikabi's Avatar
And then we got LED TVs
Old 02-27-2021, 07:47 PM   #22
Decep
Hah, i did, but of the organic variety which wear out unevenly.
RCE SS-1 Coilovers
Corsa Catback
Old 02-27-2021, 07:50 PM   #23
ermax
ermax's Avatar
Spun Rod Bearing?
Originally Posted by itsAlex View Post
Here's a video from this morning:
https://streamable.com/etti5n
I didn't realize how horrible that video was until I just took a look at it, I apologize. I'll try to take another one outdoors later today. As for the last thing I did mechanically, back in March 2020 I installed Tein Street Basis Z coilovers, nothing else has been done to the car since except swap winter tires in October.
I'll do an oil change this weekend and see what I find. Also, car has never been tracked. As far as aggressive driving goes, I'll do the occasional hard pull on the highway once in a blue moon. Other than that, I'm pretty conservative with my driving as I try to make a tank of gas last me for two weeks before having to go to the gas station. I try to never shift past 2900rpm, its where I set my shift light to go off.
This is for sure NOT rod knock. It’s way to fast. Do you have an auto? Maybe it’s the vacuum pump?
I don’t know, maybe it is, it’s hard to tell how high you are reving in the video.
Old 02-28-2021, 12:18 AM   #24
itsAlex
itsAlex's Avatar
This is exactly how I feel about the situation at the moment. I drove the car very conservatively for the past 5 years I've owned it, occasionally had a bit of fun on snowy days but apart from that, in hindsight, I wish I had enjoyed the car a bit more. I feel like if this could have happened to me, it could have happened to anyone.
I will try to upload a better video sometime soon, this video was taken in an underground parking lot at my workplace, so a lot of echoes and reverberation. It's a manual, in the video the knocking sound started at 2000 rpm and I didn't go past 3000 rpm.
Old 02-28-2021, 01:17 PM   #25
itsAlex
itsAlex's Avatar
I checked my oil today, I didn't see anything in it that stood out. The dip stick indicated it was on the low side however, just a bit over the bottom hole on the stick.
I took two videos today, hopefully you can hear the noise a bit better. The first video is light revving between 2000 and 3000 rpm:
https://streamable.com/efk316
The second video is more aggressive revving:
https://streamable.com/5h9oqe
I have a service appointment with Toyota tomorrow morning. I'll update later with their findings.
The Following User Says Thank You to itsAlex For This Useful Post:
humfrz (02-28-2021)
Old 02-28-2021, 06:33 PM   #26
ermax
ermax's Avatar
That is some intense knocking. The bearing must be entirely pounded out to be that noisy. I find it really strange nothing is in the oil. Did you simply pull the stick to check for material or did you drain the oil? If you only pulled the stick then you probably will not see anything. If you drained the oil and nothing came out then I’d say it’s not a bearing. Maybe an ejected rocker or something. If the oil was just over the bottom dot then you aren’t low enough to cause issues. The bottom dot marks the 1qt low mark. It’s not great to be almost a qt low but it’s not automatic spun bearing territory.
What year is your car?
Also, don’t do anymore revving of the engine or driving until you figure out what it is.
Old 02-28-2021, 09:57 PM   #27
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If it ejected a rocker it will not have oil pressure.
NoHaveMSG is online now   Reply With Quote
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
ermax (02-28-2021), Ultramaroon (02-28-2021)
Old 03-02-2021, 12:04 AM   #28
Icecreamtruk
Drives: Track preped NA FRS
That is knocking, hard. You need a new engine (used or rebuild that one).
Icecreamtruk is offline   Reply With Quote
2013 FR-S Spun Bearing kyjondeere Issues | Warranty | Recalls / TSB 1 09-14-2018 10:24 AM
Spun Rod Bearing Warranty Service Reprobate Issues | Warranty | Recalls / TSB 93 08-17-2018 03:39 PM
Need help, spun rod bearing, vvt parts missing faninos Issues | Warranty | Recalls / TSB 3 07-12-2018 04:11 PM
Spun Rod Bearing #4 KE70 Issues | Warranty | Recalls / TSB 13 07-05-2016 04:17 PM
Likely hood of a spun bearing aquaman Engine, Exhaust, Transmission 14 02-24-2016 02:37 PM
