Old 02-16-2021, 12:05 PM   #1
czellers
czellers's Avatar
Drives: 2K19 GT86
Cooling Dilemmas
My plan is to go turbo next year. I dont care if I buy a full kit, partial kit, or piece by piece with custom fabrication.. One thing I CANT get past is how often I see an entire half on an intercooler covered by an oil cooler, or the oil cooler and intercooler COMPLETELY covering the radiator...
At what point is there a legitimate concern around the degradation of air flow to these devices? i bothers me that its just, a "jam all that shit in the front bumper" type deal... likely due to so many being dailys i would guess..?
Any rule of thumb to follow for a fully thought out plumbing/placement strategy other than throwing the shit together?
czellers is offline   Reply With Quote
Old 02-16-2021, 02:54 PM   #2
CSG Mike
CSG Mike's Avatar
divorce everything you can.
ls1ac (02-17-2021)
Old 02-16-2021, 09:31 PM   #3
czellers
czellers's Avatar
Drives: 2K19 GT86
I've noticed a sizeable empty space behind the passenger side fog light, and presumably another on the driver's side once I remove the windshield washer fluid container. Curious if an oil cooler would fit in there.. been looking to see if there's any BRZs with a top mount intercooler..
The Following User Says Thank You to czellers For This Useful Post:
JesseG (02-20-2021)
Old 02-16-2021, 09:42 PM   #4
86TOYO2k17
Drives: 2017 toyota 86
Lots of space behind passenger side for oil cooler, and once WWF Reservoir is gone/relocated an equally large space behind driver side.
Lots of people put oil and trans cooler (for autos) on those spots (myself included). Search around lots of posts already about all this.
The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post:
JesseG (02-20-2021), omegared19 (02-19-2021)
Old 02-16-2021, 10:08 PM   #5
CSG Mike
CSG Mike's Avatar
You'll need to guide the air there and allow for an outlet. Otherwise, it's a very low flow area.
Irace86.2.0 (02-16-2021)
Old 02-16-2021, 10:52 PM   #6
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Kraftwerks/skunk2 sell a smaller replacement washer fluid resivor thay will free up enough room without loosing or relocating it.
Also look up v-mount intercooler setups to minimize stacking.
The Following 2 Users Say Thank You to Kiske For This Useful Post:
czellers (02-16-2021), omegared19 (02-19-2021)
Old 02-16-2021, 11:04 PM   #7
86TOYO2k17
Chase bay’s reservoir small and easy to mount.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
airrick (02-17-2021)
Old 02-17-2021, 01:03 AM   #8
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I don’t understand your problem fully. Is this just an aesthetics thing or an OCD thing? Do you believe you will have a problem with cooling when you take the car to the track?
Old 02-17-2021, 02:57 AM   #9
tomm.brz
Drives: brz 2017 hksv2
best way is to put an oil cooler on the side as hks do
Old 02-17-2021, 10:01 AM   #10
czellers
czellers's Avatar
Drives: 2K19 GT86
Thats my plan. its amazing the access that exists from the factory behind/below the headlights to those empty areas... almost like they KNEW there would be intercooler plumbing eventually.
JesseG (02-20-2021)
Old 02-17-2021, 12:32 PM   #11
tomm.brz
well, depends where you buy it
in italy you have fog lights and headlights wash sprayers there so you have to remove both of them to fit an oil cooler
Old 02-17-2021, 03:22 PM   #12
CSG Mike
CSG Mike's Avatar
Hotter cooler in front of a cooler cooler.
The intercooler then becomes an interwarmer.
Old 02-17-2021, 03:30 PM   #13
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
To think manufacturers even put a AC condenser in front of the radiator. Well have to move that now. Hot weather turn the AC on preheat the radiator. It just can`t work!
Will It?
Old 02-17-2021, 03:48 PM   #14
Irace86.2.0
Intercoolers, oil coolers, brake ducting, anything. Most cars have dead space there if not used for those things or something else like mentioned: fog lights, etc.
Oil Cooling - An In-Depth Look VerusEric Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 115 02-20-2023 11:54 PM
LS3 BRZ cooling Shahano Engine Swaps 12 10-16-2019 05:30 PM
Oil and water cooling Boba_kz Engine, Exhaust, Transmission 13 08-08-2017 04:58 AM
All your cooling needs Evasive Motorsports Groupbuys 46 07-10-2017 06:47 PM
