#29 | |
That plus you have to make sure your using high quality bearings. If driving in wet/salty/dirty conditions you'll need to replace the bearings a little sooner. They'll last longer with rubber booties. If it's a control arm with adjustable rod ends, it's pretty easy and cheap to service. - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | new2subaru (12-03-2020) |
#30 |
#31 |
Drives: 15 Impreza
Rallispec has a decent list for the STI hardened suspension bushings. http://rallispec.com/mou_bush_rstbkbrz.html
| The Following User Says Thank You to cueball89 For This Useful Post: | Capt Spaulding (12-05-2020) |
#32 |
#33 | |
2013 Series 10 FRS #553
#34 |
Nah that's not too bad...at first...but then you add installation cost to all of that and it does add up to be quite a bit.
There are a few spots where it makes more sense to replace the full arm or component instead with STI or aftermarket. - Andrew |
#35 |
Drives: FR-S Whiteout
A little update on the whiteline front lower control arm bushings. So far so good. Steers straight even with a bit of toe out. No darty feeling with 1/8” of toe out before I put it back to 0°
Not quite sure how I feel about how the bushing and the control arm is held in place, but no problems so far.
Intent > Content
cowardice is the mother of cruelty. |
#36 |
#37 |
You are an absolute legend. Seriously cannot thank you enough for this (as well as help you've provided in other threads.)
| The Following User Says Thank You to ninzuh For This Useful Post: | Racecomp Engineering (12-28-2020) |
#38 |
Drives: 13 FRS
I need to replace the rear subframe / diff bushings on my car.. but after watching how-to's i realized this is outside my paygrade and i don't have the necessary tools
A shop will be doing the bushings for me. Is there anything else I should have them replace while the rear-subframe is out? I can do shocks and end links and LCAs and what not myself. but any parts i can hand them while they got the subframe bushings out that would be worth while? all parts will be OEM from Toyota. Thanks |
#39 | |
https://www.subaruparts.com/oem-part...ber-20152ca000 Please keep in mind the 2017+ twins have revised front diff bushings, so be sure to get those if you are staying OEM. Hell, while you’re in there may as well throw in a 2017 diff which comes with those bushings and you get the sweet sweet 4.3FD. |
| The Following User Says Thank You to norcalpb For This Useful Post: | Racecomp Engineering (02-16-2021) |
#40 |
One other thing that I forgot to mention on the strut and shock parts...if you're trying to put together a complete assembly, there are a few more (small) parts needed. Usually they're parts you reuse so I didn't list them, but I'll go back and put the part numbers in at some point.
- Andrew |
#41 | |
- Andrew |
#42 |
Drives: 13 FRS
just realized the subframe bushings themselves dont come with the rear subframe (which includes the DIFF bushings)
Are you supposed to swap out the subframe bushings? |
| Air Suspension / Brembo Brakes / RUCA | bansky | Brakes, Suspension, Chassis | 17 | 04-14-2019 06:31 PM |
| 2014 BRZ Brakes and Suspension | AndyBRZ | Brakes, Suspension, Chassis | 1 | 03-11-2018 12:01 AM |
| OEM brakes and suspension | batlwagn | Brakes, Suspension, Chassis | 3 | 04-04-2016 05:13 PM |
| Memorial Day Sale. Brakes and Suspension 10-25% off! | Infamous Performance | Brakes, Suspension, Chassis | 31 | 06-06-2015 02:52 PM |
| Turn in Concepts Brakes, Suspension, Chassis | Turn in Concepts | Brakes, Suspension, Chassis | 13 | 01-22-2014 05:14 PM |
