#99 |
Did you check your alignment settings after installing?
#100 |
Drives: 2017 86
No, it supposedly does not alter alignment and I'm not driving 100 miles a month and the rims & tires are coming off when my new ones come at which point, I'll have the car aligned.
| The Following User Says Thank You to e30cabrio For This Useful Post: | Tokay444 (02-14-2021) |
#101 | |
Drives: FR-S Whiteout
Oh wow.. Now I cant wait till the next stimulus drops. lmao jk
Intent > Content
cowardice is the mother of cruelty. |
#102 |
Steve Bodalenko
Drives: Toyota 86 GTS
#103 | |
Steve Bodalenko
Just watch fitting them. Those subframe bolts can be buggers to realign and will cross thread very easily. ALWAYS install with fingers. If installed properly the bolts should almost tighten up by hand till the last couple of threads. Then you can uses a socket and bar. Ask me how I know
| The Following User Says Thank You to Bodalenko For This Useful Post: | jeepmor (04-07-2022) |
#104 |
Because compromise ®
Drives: Red Herring
| The Following User Says Thank You to Captain Snooze For This Useful Post: | solidONE (03-03-2021) |
#105 |
Intent > Content
#106 | |
How about on the brakes? Does it not want to rotate as much on corner entry.
Intent > Content
#107 |
Drives: Red Herring
Are you serious? This is the suspension thread; they are obviously aftermarket bushes. Well, young, immature bushes.
Here is a picture of a rubber bush. I couldn't find a pic of a poly bush.
| The Following 3 Users Say Thank You to Captain Snooze For This Useful Post: |
#108 |
Drives: 2017 86
I'm selling my car and my mca mod is for sale in the member classified suspension section
#109 |
Drives: 2020 BRZ Sport Tech RS
Latest mod installed today - MCA Traction Mod:
![]() Installing on jack stands in my garage was not super fun...LOL. Also, if you ever do this mod, do yourself a favour and do ONE SIDE AT A TIME. I.E. do EVERYTHING on the one side, then start the other. Trust me. Haven't had a chance to really push it in the twisties yet (my favourite roads are currently cut off by flooding due to heavy rains over the last few days), but I took it through some of the spots around town where I've had some code brown moments with the back snapping out mid-corner and my first impressions are that it does what it says on the tin - puts the power down much better through corners and particularly bumpy corners. Before, it felt twitchy and would snap into oversteer when the outside rear loaded up suddenly and the diff would shunt the power to that wheel, but now it's WAY more planted. Helical diffs on FWD are friggin magic - when the outside wheel loads up, it just shunts torque to that wheel, tucks in and drives the front end around the corner. I installed a Quaife diff in my Tiburon, and it was insane how well it could put power down in corners. With the BRZ's stock behaviour, I was having my doubts whether the same type of diff made sense in a RWD car. With this mod, I feel like it more progressively loads the outside wheel, making the diff behave better. The car feels like it has more of the balance it should have had from the factory as a proper sports car. HIGHLY RECOMMENDED MOD, for sure!
#110 | |
#111 |
Zero - I'm on stock (Performance Pack) springs and Sachs dampers.
For what it's worth, with how much that pickup point is lowered by the Traction Mod, to get the same reduction in anti-squat from lowering the ride height would require about a 50mm drop, which would have very little, if any, suspension travel left. UPDATE: Got a chance to push it a bit more on some of the local roads in the dry, and all I can say is WOW. This is how the car should have been from the factory. Puts the power down so much better, and the rear end behaviour is much more predictable.
Last edited by Tatsu333; 11-18-2021 at 01:11 AM. Reason: EDIT 1: Added note RE: change in pickup point EDIT 2: further driving impressions |
| The Following User Says Thank You to Tatsu333 For This Useful Post: | gpvecchi (11-18-2021) |
#112 |
Drives: '13 FRS - STX
What's the rear alignment like?
| Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? | davidchoi | Cosmetic Modification (Interior/Exterior/Lighting) | 49 | 11-22-2014 11:17 PM |
| "Clicking" or "knocking" caused by rear seat pull down lever. | husker741 | Issues | Warranty | Recalls / TSB | 6 | 11-27-2013 03:30 PM |
| "My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") | levifig | BRZ First-Gen (2012+) — General Topics | 48 | 08-09-2013 07:34 PM |
| Factory suspension "sticktion" | andrew20195 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 04-02-2013 03:49 PM |
| "Official" Suspension/Brake Thread | NYC BRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 06-27-2012 10:14 PM |
