Old 01-31-2021, 01:10 PM   #1
GTRS_FK
Drives: GTR R35 // AUDI RS3
Looking to buy - FOUND THIS
Looking at BRZ for track day manual fun
Found this car for equivalent $13,000. Very clean. My question is, I'm buying to turn into a track car as my GTR is too costly to run on the track and my RS3 I use as a daily. As far as spec goes how quick will this be from stock, and do you think its a good start on which to build on (buckets, further weight reduction, coil overs etc.)
2016
31000kms full history
Grey
Tomei unequal length headers
Catless
Tomei overpipe
Jdl ultra quiet front pipe
Invidia q300 catback
Tein springs
Oft stage 2+
Stainless steel brake lines
Valenti tail lights
Brake brace
Rpf1 wheels 18inch
All original parts are still available
Sent from my SM-N986B using Tapatalk
GTRS_FK is offline   Reply With Quote
Old 01-31-2021, 01:48 PM   #2
GTRS_FK
And the tyres a potenzas 235/40 front and 265/35 rear
Old 01-31-2021, 02:43 PM   #3
GTRS_FK
Finally intake is the normal drop in, owner has both the injen intake and a takeda momentum which he said he fitted but then removed as no need doesn't make much gain and also a proper tune is needed to adjust the MAF.
Does this sound correct?
Old 01-31-2021, 03:25 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
looks like a pretty good start to me as long as your pre-purchase inspection doesn't turn up any signs of significant damage.
Old 01-31-2021, 03:40 PM   #5
TommyW
TommyW's Avatar
Drives: '13 Whiteout
If the wheels are the same size I'd look into a square tire setup when you're ready for new ones.
TommyW is offline   Reply With Quote
The Following 2 Users Say Thank You to TommyW For This Useful Post:
Dzmitry (02-18-2021), Grady (01-31-2021)
Old 01-31-2021, 05:58 PM   #6
Grady
Grady's Avatar
And a lot less tire, 265 is way to much for your power! All that is doing is slowing you down.
The Following User Says Thank You to Grady For This Useful Post:
Old 01-31-2021, 06:14 PM   #7
TommyW
TommyW's Avatar
Not to mention that setup affecting the handling balance.
235 square is plenty of rubber. I've run 225, 235 and now on 245 and will go back to 235
Old 01-31-2021, 09:50 PM   #8
GTRS_FK
I thought this also
Old 01-31-2021, 09:50 PM   #9
GTRS_FK
Thanks for the tip
Old 02-17-2021, 08:07 PM   #10
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
This looks like a bangin' deal, no?
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 02-18-2021, 07:53 AM   #11
Are you able to transfer ownership on a catless car in the UK? I thought they had some pretty strict inspection requirements. Is it even an issue if just a track toy?
~ Found ~ Thanks ~ Mr.Impreza Canada Classifieds 7 12-13-2017 03:08 PM
FOUND ! trueno86power Want-To-Buy Requests 6 04-14-2016 07:27 PM
Found chuccwagon Want-To-Buy Requests 0 02-04-2016 02:49 PM
FOUND sixthree Canada Classifieds 0 05-02-2014 01:54 AM
i just found out... NESW20 Other Vehicles & General Automotive Discussions 8 11-20-2009 06:56 PM
