Old 01-28-2021, 09:52 PM   #1
yoursecondguess
Drives: Frs
Condensation Build up in Valenti
Hey community, I know this is a very common problem and I'm ordering ninjagaskets to prevent it in the future, but before that, does anyone have an easy method of removing the water from the tail light? I have like an inch build up and I didn't even notice it because its always raining.
Thanks in advance!
yoursecondguess is offline   Reply With Quote
Old 01-29-2021, 07:43 AM   #2
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
Put it in a sack of rice for about a day or more. It's a cheap yet very effective way to absorb moisture. It's the method used on submerged phones.
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
Old 01-29-2021, 07:55 AM   #3
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Please don't.
That isn't how rice works.
You have no idea how many peoples laptops and phones I have opened due to water damage and finding the laptops in particular being full of rice and still having water inside.
Put thing like that in in a container with actual moisture absorbing packets like damp rid.
That would be more likely to do something, even then I doubt It'd do much.
Old 01-29-2021, 12:22 PM   #4
RickyBobby
Drives: 2013 Firestorm FR-S AT
Whatever method you use to dry these out you will probably get water spots on the inside of the lights.
I had a dent in my trunk fixed. They had to remove the original tail lights to fix it. After they re-installed them, incorrectly, they washed the car and got water in the tail lights.
After removing them, I pored a small amount of distilled water into the light socket hole, rotate the socket counter-clockwise to remove it, and rinsed the inside several times. I used my wife's hair dryer to dry the inside of the lights. No water spots.
Three years ago I replaced the originals with Valentis. So far no leaks. If installed correctly and the bolts torqued to spec they should not leak.
Cheapo Harbor Freight torque wrench and 20% off coupon
https://www.harborfreight.com/14-in-...nch-63881.html
https://www.hfqpdb.com/view_coupon/54104
RickyBobby is offline   Reply With Quote
Old 01-29-2021, 12:32 PM   #5
yoursecondguess
Drives: Frs
The absorption packets seem like an interesting idea, but I agree might not help much. I’ll try that if someone doesn’t have a solution.
And yeah I didn’t install these, I bought the car years ago used with them pre-installed, didn’t build up condensation until recently without me knowing. I don’t think there’s a light socket for me to pour water out of unfortunately.
Thanks for the suggestions so far. Please if anyone has run into this situation with valentis let me know what you did!
Old 01-29-2021, 01:30 PM   #6
rbfr.s
rbfr.s's Avatar
Drives: 2014 FR-S
Use a hairdryer to help evaporate the collected water (avoid blasting an area for too long to negate plastic warping). Correct me if I'm wrong, but there should be a couple screws you can remove on the back to help drain the water out. It's a game of tilting the tails to let water drain while also heating up the housing to help evaporate. You're almost certain to end up with water marks - I haven't tried the distilled method though.
Professional Car Breaker
rbfr.s is offline   Reply With Quote
The Following User Says Thank You to rbfr.s For This Useful Post:
x808drifter (01-29-2021)
Old 01-30-2021, 11:29 AM   #7
RickyBobby
Right, forgot these are all LEDs, but there is a cross cut (see pic) where the wires go in that you maybe can add and remove distilled water with a plastic syringe and, if needed, a small plastic hose. Yeah, sounds a little crazy adding water when you are trying to get it out.
Name:  Valenti back tail light.jpg
Old 01-31-2021, 01:09 AM   #8
Impureclient
Drives: 2015 FR-S
Why not add denatured alcohol instead to remove spotting?
Old 01-31-2021, 09:20 AM   #9
RickyBobby
https://chemistry.stackexchange.com/...0less%20polar.
https://www.instructables.com/Why-Yo...ol-Methyl-Eth/
The Following 2 Users Say Thank You to RickyBobby For This Useful Post:
churchx (02-02-2021), Impureclient (01-31-2021)
Old 02-02-2021, 03:11 AM   #10
Purist
Purist's Avatar
Drives: Subaru BRZ
This should work...
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
The Following 5 Users Say Thank You to Purist For This Useful Post:
churchx (02-02-2021), Impureclient (02-04-2021), NWFRS (02-03-2021), soundman98 (02-02-2021), x808drifter (02-02-2021)
Removing Condensation from Valenti tails? Kushkaki Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 11-29-2018 12:29 PM
Valenti Taillights - Condensation? 636 Cosmetic Modification (Interior/Exterior/Lighting) 27 12-14-2017 02:20 AM
Condensation in Sequential Valenti Tail Lights? fizzymike Cosmetic Modification (Interior/Exterior/Lighting) 12 09-07-2016 08:29 PM
Valenti Tail Lights Condensation Issues merdok12 Cosmetic Modification (Interior/Exterior/Lighting) 2 01-31-2016 06:09 PM
Valenti Red Lens Tail Light-moisture build-up Agent 86 Cosmetic Modification (Interior/Exterior/Lighting) 86 12-21-2015 01:22 PM
