Old 01-13-2021, 09:39 AM   #2437
meWant
Drives: '16 BRZ Limited
I was looking at just getting a smaller fan, but not sure if there's a major difference in 120mm cooler fans. Issue is i can't close the side panel with the included fan installed so right now only running 1 of the 2 140mm fans that came with the cooler.
Have you considered water cooling?
I would prefer to stick with an air cooled set up, at least for now especially while parts are still harder to get. Also a little nervous with water cooling since this was my first build
meWant is offline   Reply With Quote
Old 01-13-2021, 09:36 PM   #2438
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
120mm is just a smaller fan. It's better having a smaller fan blowing air than one doing all the work.
Don't be scared with water cooling. All in one aka AIO are just as simple. Just make sure your case can fit one. That's pretty much it.
I did my first build two years ago and I went with an AIO. Zero maintenance.
The Following 2 Users Say Thank You to Mr.ac For This Useful Post:
soundman98 (01-14-2021), Spuds (01-13-2021)
Old 01-13-2021, 09:41 PM   #2439
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I did my first liquid cooler with my first time building a PC. AIOs are pretty straight forward. If you can do an air cooler, you can do an AIO. I got the BeQuiet Pure Loop 120mm.
If you're set on a slim air cooler, look into the Noctua NH-L9a
MS, CSCS, TSAC-F, CPT
The Following 3 Users Say Thank You to weederr33 For This Useful Post:
meWant (01-13-2021), soundman98 (01-14-2021), Spuds (01-13-2021)
Old 01-13-2021, 10:49 PM   #2440
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
As others have said, all in one water coolers are just as easy to set up as air coolers. The pump unit is small and attaches to the CPU, and the radiator/fan just takes over a fan mount on your case. Most newer cases have thick enough fan mounting locations to support a radiator/fan combo.
The Following User Says Thank You to Spuds For This Useful Post:
meWant (01-13-2021)
Old 01-13-2021, 11:40 PM   #2441
meWant
Hmm probably should've researched better prior to purchasing lol. Everything has been assembled since Christmas eve so no more returning for me
The Following User Says Thank You to meWant For This Useful Post:
Spuds (01-14-2021)
Old 01-14-2021, 01:02 AM   #2442
Spuds
The Dictater
Spuds's Avatar
Well, now you can get the mod bug for your PC lol. Think of it as a learning experience. Research is good for figuring out what to do, but truly learning why requires experience. CPU cooler interference is probably the hardest aspect of a build to predict so if that's the only issue you got out of your first build then you did pretty good.
Old 01-14-2021, 01:07 AM   #2443
soundman98
ProCrastinationConsultant
soundman98's Avatar
$100 learning experience is really getting off cheap.
i had some bad pc memory a while back once. it only caused problems in very specific games at different times. i replaced a $200 power supply because it seemed more voltage related than a bad memory sector-- like my graphics card was pulling more than my power supply could take...
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
meWant (01-14-2021), Spuds (01-14-2021)
Old 01-14-2021, 01:20 AM   #2444
meWant
Oh for sure. Even with just one fan on the heatsink cpu idle is around 38-40ish degrees. So not too bad just sure it could go lower with a second fan probablh
Old 01-14-2021, 03:00 PM   #2445
weederr33
weederr33's Avatar
I didn't see this posted, but gave very strong Dead Space vibes
Old 01-14-2021, 03:12 PM   #2446
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
So I followed the advice I got from the forums and changed my plans for the build. This is what I came up with, so far I've only purchased the case and motherboard, no rush on the rest of the stuff since I can't find a GPU anyways.
CPU:AMD Ryzen 5 3600 6 core
SSD:Adata XPG Pro 1TB SSD
Power: Corsair CX750 750W Fully modular
Cooling: Corsair Hydro Series H60 AIO
RAM: Corsair Vengeance LPX 16GB
Motherboard: ASUS ROG Strix B550
GPU I'm thinking maybe I'll get lucky and get my hands on a 3060ti.
spcmafia is online now   Reply With Quote
The Following 4 Users Say Thank You to spcmafia For This Useful Post:
Dadhawk (01-14-2021), meWant (01-15-2021), soundman98 (01-14-2021), weederr33 (01-14-2021)
Old 01-14-2021, 04:24 PM   #2447
Spuds
The Dictater
Spuds's Avatar
That seems like a legit build to me. Don't forget to budget for an operating system.
Dadhawk (01-14-2021), spcmafia (01-14-2021)
Old 01-14-2021, 04:31 PM   #2448
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
AIOs are passé. You need submersed mineral oil cooling.
Old 01-14-2021, 04:56 PM   #2449
weederr33
weederr33's Avatar
Seems like a good build so far! I've noticed the Ryzen 5 is very popular over the 7 or 9
The Following User Says Thank You to weederr33 For This Useful Post:
spcmafia (01-15-2021)
Old 01-14-2021, 09:24 PM   #2450
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Nice. But take advantage of the the M.2 SSD. Spend a bit more for it. Go for the NVMe one, I did. Makes worlds of difference. 30 seconds from completely off to watching a YouTube vid on chrome!.
And this is the Micro Center brand Inland Premium 1TB. I paid $125.
The Following 5 Users Say Thank You to Mr.ac For This Useful Post:
Dadhawk (01-14-2021), meWant (01-15-2021), soundman98 (01-14-2021), spcmafia (01-15-2021), weederr33 (01-15-2021)
pc master race, u no have 3080
gamers lounge Touge_ninja Off-Topic Lounge [WARNING: NO POLITICS] 25 01-21-2014 05:32 PM
GT Acadamy Gamers Banned from Britsh GT Pro-Am WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 16 02-11-2013 07:37 PM
