Old 01-11-2021, 08:36 AM   #1
qiumaoyuan
qiumaoyuan's Avatar
Drives: 2017 BRZ MT, 2009 Civic sedan AT
Unhappy Shadow Pro3 oil pressure gauge looks not so accurate
I am using Nutec NC-51 0w-30 engine oil, and the oil cooler is HKS S Type for 86/BRZ.
Attached images are the results measured using two gauges under the same other conditions. I believe in the accuracy of defi as an industry benchmark, so it seems that the measurement results of Shadow Pro3 are not accurate and the price is not cheap. Has anyone done a similar comparison? How is the result?
qiumaoyuan is offline   Reply With Quote
Old 01-11-2021, 09:29 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Do you have the sensor connected in the same location?
x808drifter (01-11-2021)
Old 01-11-2021, 10:29 AM   #3
qiumaoyuan
qiumaoyuan's Avatar
Yes, same location, same oil temperature, same RPM ...
Old 01-11-2021, 12:15 PM   #4
DarkPira7e
DarkPira7e's Avatar
Well as you'd alluded to, the sender is likely designed or functioning poorly in one of them. I'd send the one you trust less back for a refund and include your findings to them.
Old 01-14-2021, 08:02 PM   #5
Grady
Grady's Avatar
Use the one with higher oil pressure. Car wont care, you will feel better!
Old 01-18-2021, 04:27 PM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
Only about 5 Bar in it, probably not that far outside of tolerance on sensors between the 2. Both give you a good indication of the pressure, TBH both are in the ballpark of the pressures I'd expect.
.: Stealth 86 :.
Kodename 47 DJ:
defi, oil pressure, shadow
oil pressure gauge onemorelap Engine, Exhaust, Transmission 69 03-04-2023 05:46 PM
AEM Oil Pressure Gauge Chumblebee Audio/Visual, Electronics, Infotainment, NAV 1 06-11-2018 11:15 PM
Oil Pressure Gauge solidONE Engine, Exhaust, Transmission 59 04-03-2018 04:15 PM
AEM Oil temperature gauge and pressure gauge with pods. mtsound Engine, Exhaust, Bolt-Ons 2 08-24-2017 12:55 PM
Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review Tye300 Cosmetic Modification (Interior/Exterior/Lighting) 10 05-22-2015 12:48 PM
