Old 01-11-2021, 01:46 AM   #1
Kurt Sampson
Kurt Sampson's Avatar
Drives: Toyota GT86
Faulty Fuel Gauge
Good day
I have a 2013 GT86, I recently completed my engine swap (3SGE with a EMU Black stand alone management) I noticed my fuel gauge does not read accurate. After doing some research I replaced both sender units and I still have the same problem, the only way to check my fuel level is to disconnect the negative terminal from the battery for a few seconds and reconnect the battery.
has anyone have this kind of problem before?
thanks in advance
Kurt Sampson is offline   Reply With Quote
Old 01-11-2021, 04:55 AM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
How is it not accurate?
Dose not move at all?
Shows empty at half tank?
ECT.
Old 01-11-2021, 05:03 AM   #3
Kurt Sampson
Drives: Toyota GT86
sorry I should have stated the following, so if I fill up the car the gauge would show the correct fuel level and when I drive for a while the needle wont drop and in order for the needle to drop I would need to remove the battery and reconnect again after a couple of seconds to show the correct fuel level.
The Following User Says Thank You to Kurt Sampson For This Useful Post:
x808drifter (01-11-2021)
Old 01-11-2021, 05:28 PM   #4
norcalpb
norcalpb's Avatar
Try posting in the “engine swap” section, someone most likely has run into the same issue.
https://www.ft86club.com/forums/forumdisplay.php?f=92
Old 01-11-2021, 06:15 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Start here, go to post #101 and read through.
https://www.ft86club.com/forums/show...t=90692&page=8
Ultramaroon (10-01-2021)
Old 01-12-2021, 01:13 AM   #6
Kurt Sampson
Drives: Toyota GT86
thank you gents
Fuel Gauge will only go up to 3/4 william123 Issues | Warranty | Recalls / TSB 17 02-05-2021 06:58 PM
FS: AEM air/fuel gauge 264grendel Miscellaneous 16 02-24-2017 01:06 PM
Gas Gauge Faulty? Phothiraj BRZ First-Gen (2012+) — General Topics 21 06-03-2015 12:28 AM
fuel gauge/pump Reaper Forced Induction 9 03-22-2014 04:01 PM
Fuel gauge misreading actual fuel in tank. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 19 10-09-2013 04:39 PM
