Old 07-11-2019, 06:50 PM   #15
steve99
Drives: FT86
You guys need to log afr, commanded afr , maf, manifold pressure, throttle , rpm , pprt amd direct injector pulse widths. Stft, ltft so you can see ehats going on.
High positive ltft at low rpm indicates intake or exhaust leaks, cracked header or similar
High negitive trims, often dirty maf sensor or oil on maf sensor
Afr cycling between very rich amd very lean like 11 to 15 fairly quickly at idle can be failed 02 sensor
But you need to log and confirm
RedReplicant (12-06-2022)
Old 09-14-2019, 11:39 AM   #16
Kris86
Kris86's Avatar
Drives: RHD Gt86
Originally Posted by Jesse36m3 View Post
Was this ever resolved? I'm having the same issue with my fuel trims. Extreme bogging and stuttering at low rpm/throttle. Hard to accel, AFR reading max rich 11.02.
Then it suddenly clears up and is fine until it happens again.
Same issue here, did u figure it out?
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 09-14-2019, 07:22 PM   #17
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
Yes. Ended up being a bad coil pack. I replaced all 4 at the same time and it drove perfect. It wasn't apparent because I did not have a misfire code.
Jesse36m3 is offline   Reply With Quote
The Following User Says Thank You to Jesse36m3 For This Useful Post:
Kris86 (09-27-2019)
Old 08-27-2020, 08:42 AM   #18
Gloonge
Drives: 2013 frs raven
I know this was years ago at this point. But do you remember what your AFR was doing while this was going on? I am having the same issue, except I'm boosted. AFR stays at like 14.6 at idle but the stft goes to like - 25%.
Everything stays normal ish at cruising speed
Gloonge is offline   Reply With Quote
Old 08-29-2020, 12:19 AM   #19
Decep
Drives: 2013 FR-S Series 10
I had a week or so where my fuel trims would go to -29%, car ran fine otherwise.
I pulled the MAF to clean it but it was spotless and bone dry... didn't do anything to it. i reinstalled the sensor and like magic my trims went back to +0-3%
Hasn't happened since.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 08-29-2020, 08:42 AM   #20
Gloonge
I kinda did the same thing out of frustration. I am being tuned for forced induction, so these wild swings make tuning impossible and likely a little less safe.
So I cleaned the air filter, maf, map and TB all at one shot and it seems to have cleared up. Nothing looked perticularly dirty, but the issue seems to have gone away. ¯\_(ツ)_/¯
Old 09-06-2020, 01:37 PM   #21
Jesse36m3
Jesse36m3's Avatar
I was turbocharged too. AFR was super rich because spark wasn't firing due to bad coil pack.
Old 01-07-2021, 07:06 PM   #22
Gloonge
Were you having any notable running issues other than the super negative fuel trims?
Like if you didn't have the ability to datalog would you have had any reason to assume there was an issue?
Old 09-30-2025, 04:10 PM   #23
Teseo
Drives: frs
So could be 2 factor:
Coil packs
MAF/intake related
I did the maf cleaning with CRC maf cleaner and ran ok for a while. Then started to have that bogging on/off throttle in lower RPM's with negative LT Fuel trim (-17.98%).
Coil packs swap next?
bogging, bucking, high fuel trim, high pitch noise
Diagnosing high positive LTFT Tectoniic Software Tuning 22 05-03-2022 03:24 AM
Is it normal for STFT and LTFT to always be 5% above? pcguru2000 Issues | Warranty | Recalls / TSB 3 04-13-2018 09:36 PM
High Negative LTFT on N/A BRZ causing idling issues paintdude258 Software Tuning 57 03-26-2017 09:14 AM
high ltft while running e85 with oft flat4_86 Software Tuning 4 01-22-2017 01:47 AM
high ltft at idle, my how to fix it(not fixed yet) trdric Software Tuning 16 06-18-2015 11:27 PM
