Old 12-03-2020, 10:45 AM   #29
Racecomp Engineering
Originally Posted by new2subaru View Post
Hi Andrew, how do you feel about large and small bushings being replaced with spherical bearings? Anything to watch out for?
It's talked about somewhere else on the forum, but as you replace OEM bushings with stiffer pieces (especially spherical bearings) it really highlights what your dampers are doing. Pretty much everything will feel a little more harsh...not always that bad but if using shocks that have some bigger deficiencies those will be highlighted. Or you may have to do some extra shock tuning if you have that capability.
That plus you have to make sure your using high quality bearings. If driving in wet/salty/dirty conditions you'll need to replace the bearings a little sooner. They'll last longer with rubber booties. If it's a control arm with adjustable rod ends, it's pretty easy and cheap to service.
- Andrew
new2subaru (12-03-2020)
Old 12-03-2020, 10:46 AM   #30
Originally Posted by ninzuh View Post
That would be unbelievably appreciated.
Working on it! Sorry busy couple of weeks.
- Andrew
Old 12-05-2020, 09:44 AM   #31
cueball89
Drives: 15 Impreza
Rallispec has a decent list for the STI hardened suspension bushings. http://rallispec.com/mou_bush_rstbkbrz.html
cueball89 is offline   Reply With Quote
The Following User Says Thank You to cueball89 For This Useful Post:
Capt Spaulding (12-05-2020)
Old 12-21-2020, 05:07 PM   #32
Haven't forgotten about this, and might actually have some time to finish this in the next week.
- Andrew
Old 12-21-2020, 11:05 PM   #33
jflogerzi
jflogerzi's Avatar
1400$ for the whole kit are they nuts!
2013 Series 10 FRS #553
Old 12-22-2020, 11:22 AM   #34
Nah that's not too bad...at first...but then you add installation cost to all of that and it does add up to be quite a bit.
There are a few spots where it makes more sense to replace the full arm or component instead with STI or aftermarket.
- Andrew
Old 12-22-2020, 06:32 PM   #35
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
A little update on the whiteline front lower control arm bushings. So far so good. Steers straight even with a bit of toe out. No darty feeling with 1/8” of toe out before I put it back to 0°
Not quite sure how I feel about how the bushing and the control arm is held in place, but no problems so far.
Intent > Content
Old 12-28-2020, 02:10 PM   #36
Does anyone know if there's a list out there of all the OEM Bushing Part #'s ? Looking to do a full bushing refresh on my MY13. The Toyota parts site is a little confusing and want to make sure I'm not missing any bushings.
Just updated post #3.
- Andrew
Old 12-28-2020, 03:29 PM   #37
ninzuh
You are an absolute legend. Seriously cannot thank you enough for this (as well as help you've provided in other threads.)
ninzuh is offline   Reply With Quote
The Following User Says Thank You to ninzuh For This Useful Post:
Racecomp Engineering (12-28-2020)
Old 02-13-2021, 09:35 PM   #38
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
I need to replace the rear subframe / diff bushings on my car.. but after watching how-to's i realized this is outside my paygrade and i don't have the necessary tools
A shop will be doing the bushings for me. Is there anything else I should have them replace while the rear-subframe is out?
I can do shocks and end links and LCAs and what not myself.
but any parts i can hand them while they got the subframe bushings out that would be worth while?
all parts will be OEM from Toyota. Thanks
RickyRacer is offline   Reply With Quote
Old 02-16-2021, 02:08 PM   #39
norcalpb
norcalpb's Avatar
One option is to replace the entire subframe as I believe* it comes with new subframe and rear differential bushings.
https://www.subaruparts.com/oem-part...ber-20152ca000
Please keep in mind the 2017+ twins have revised front diff bushings, so be sure to get those if you are staying OEM. Hell, while you’re in there may as well throw in a 2017 diff which comes with those bushings and you get the sweet sweet 4.3FD.
The Following User Says Thank You to norcalpb For This Useful Post:
Racecomp Engineering (02-16-2021)
Old 02-16-2021, 02:13 PM   #40
One other thing that I forgot to mention on the strut and shock parts...if you're trying to put together a complete assembly, there are a few more (small) parts needed. Usually they're parts you reuse so I didn't list them, but I'll go back and put the part numbers in at some point.
- Andrew
Old 02-16-2021, 02:15 PM   #41
Possibly the upper control arm bushings. Or the full arm assembly with ball joint (possibly easy enough to do yourself, but super easy if you have the subframe out).
- Andrew
Old 03-04-2021, 09:43 PM   #42
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
just realized the subframe bushings themselves dont come with the rear subframe (which includes the DIFF bushings)
Are you supposed to swap out the subframe bushings?
Air Suspension / Brembo Brakes / RUCA bansky Brakes, Suspension, Chassis 17 04-14-2019 06:31 PM
2014 BRZ Brakes and Suspension AndyBRZ Brakes, Suspension, Chassis 1 03-11-2018 12:01 AM
OEM brakes and suspension batlwagn Brakes, Suspension, Chassis 3 04-04-2016 05:13 PM
Memorial Day Sale. Brakes and Suspension 10-25% off! Infamous Performance Brakes, Suspension, Chassis 31 06-06-2015 02:52 PM
Turn in Concepts Brakes, Suspension, Chassis Turn in Concepts Brakes, Suspension, Chassis 13 01-22-2014 05:14 PM
