Old 12-21-2020, 01:41 PM   #1
MichaelJohn
18BRZ, 95M3, GT3, S402
MichaelJohn's Avatar
Drives: 18BRZ 09GT3 95M3LWT S402 replica
Lighter headers without added noise?
New to the forum. Have a 2018 brz since new. Did the indivia v2 exhaust and love the exhaust note. Want a lighter header setup without adding (too much more) noise. Possible?
MichaelJohn is offline   Reply With Quote
Old 12-21-2020, 01:56 PM   #2
Ashikabi
Ashikabi's Avatar
Lighter than stock? I think they all are. A catted header will be the quietest. Still louder than stock though
Sent from my ONEPLUS A5010 using Tapatalk
Old 12-21-2020, 02:13 PM   #3
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
JDL Catted Header. Pricey, but is great quality. Did make my exhaust a bit louder (Q300), but nothing overly obnoxious, if anything makes it deep yet aggressive.
spcmafia is offline   Reply With Quote
Old 12-21-2020, 03:29 PM   #4
Welcome to our forum -
Your car looks good -
If you liked the sound like it is, I suggest you just leave the exhaust system alone.
Old 12-21-2020, 03:38 PM   #5
alphasaur
friendly
Drives: 17' 86
Anytime you play with the cats the car will get louder. AFE has a catted EL header so the tone won't really change vs stock.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 12-21-2020, 03:47 PM   #6
czellers
czellers's Avatar
Drives: 2K19 GT86
Super clean!
czellers is offline   Reply With Quote
Old 12-21-2020, 03:53 PM   #7
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Take the heat shields off.
BigTuna is offline   Reply With Quote
Old 12-21-2020, 04:38 PM   #8
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Remove the oem cat will reduce weight. Otherwise look into a good header for your budget. Regardless it will add more sound. But that's a subjective thing.
MS, CSCS, TSAC-F, CPT
Old 12-21-2020, 06:53 PM   #9
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
FTSpeed/FT86 Speedfactory just got their ceramic coated header back with a new bronze coating. Otherwise if you want the best money can buy? Fujitsubo.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 12-21-2020, 09:57 PM   #10
jflogerzi
jflogerzi's Avatar
If you have E85 around. Just get Flex Fuel and ecutek tune from CSG. Better than getting a header. If you want a bit more noise switch our your Front pipe.
2013 Series 10 FRS #553
Old 12-21-2020, 10:24 PM   #11
MichaelJohn
Thanks all for the responses. Again I'm reducing weight in the car. Not looking at more power. At 2602lbs right now (no driver/half fluid/no junk in the trunk/LW battery/rear seat delete and other stuff removed) Shooting for 2580ish. I like the sound it currently makes, but could go a little more louder for weight loss. speedfactory headers are too loud. heard them in person. I'll keep searching. Best.
Old 12-21-2020, 11:13 PM   #12
jflogerzi
jflogerzi's Avatar
your not get quiet and light with headers on this car
The Following User Says Thank You to jflogerzi For This Useful Post:
PulsarBeeerz (12-22-2020)
Old 12-21-2020, 11:33 PM   #13
86TOYO2k17
Drives: 2017 toyota 86
When i was NA, I had ace header, hks double res FP with csg mxp touring 86.
Sounded great, and was barely louder then stock especially when cruising.
Csg mxp is one of the best CBEs if you want good tone but little added noise.
I believe ace is 12lbs lighter too.
I dropped over 190lbs without sacrificing any driver comforts, actually reduced cabin noise in the process. AC delete for most people would be the only driver comfort i got rid of, but i never used the AC until after I deleted it. The fans work decently well with no freon.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
HaXx (12-21-2020)
Old 12-21-2020, 11:36 PM   #14
HaXx
Drives: jrsc_brz
Welcome to the forum,
nobody really talks about lightweight headers, thats not really a topic of discussion.
im happy to offer some ways to lose weight tho:
if you want to loose weight, the first and second place to look is wheels+tires. im not sure but it **looks** like youre rocking federal 595 tires which are the heaviest tire in the milky way galaxy. every pound on your wheels+tires equates to be equivalent to ~ 10lb up on the car. so loosing 2 lbs on a header aint jack compared to 2lb on your tires. tirerack lists tire weight in the specs, indy500 are among the lighter options.
if youre serious about loosing weight, look into nonheated nonreclineable seats, titanium single exit catbacks(1 muffler weighs less), titanium front pipe, ditch your a/c, lightweight flywheel, carbon driveshaft, get a steering wheel with no airbag, yeah lightweight headers arent really a thing. im sure some headers weigh less, but there are better ways to slim down.
your invidia exhaust is probably lighter than factory, but a pig compared to a Titanium Tomei. a quick google says the invidia n2 weighs 22kg=48lbs,
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
VVT Tuning Noise - ADDED: Comparison Video Dezoris Software Tuning 349 01-27-2020 04:46 AM
Swoosh noise headers NoobBRZ Engine, Exhaust, Transmission 18 01-31-2018 03:12 PM
Exhaust Cabin Noise, MXP UEL Headers and OP, Tsudo Catback HachiEnam Engine, Exhaust, Transmission 25 12-15-2015 06:47 AM
Road and Track: Tune + headers + axleback added to long term BRZ tennisfreak Engine, Exhaust, Transmission 42 01-07-2014 04:31 PM
[Bought] Borla (or lighter) headers Anthony Want-To-Buy Requests 4 08-28-2013 12:55 PM
