| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 | |
Drives: '23 BRZ
I'd stick to zero to 0.1 degrees total rear toe-in. Adding rear toe-in isn't going to magic you more grip, but it will make the car less responsive and less fun to drive. |
| The Following User Says Thank You to ZDan For This Useful Post: | gpvecchi (12-15-2020) |
#16 |
It's not a matter of more grip, it's that when it loose grip it's sudden and not progressive. For sure it's not the PS4 that have not enough grip...
If you want responsiveness, start changing all that shitty bushings our car have. My Fiat Panda has stiffer bushings. |
#17 | |
Drives: '23 BRZ
That's been my experience with this car, I've run both 0 and 0.1deg. On other cars with heim joints and aluminum/delrin bushings, I've found too much rear toe (in excess of 0.3 degrees) to suck, bad, for everything, but 0 to 0.1 even 0.15 degrees no probs... Losing grip suddenly and not progressively can be a characteristic of how the tire grips. Some tires have a lot of latent grip after wheelspin or sliding begins, and some have less. MPSS I had on the FD RX-7 were kind of the worst in this regard after 2 years on them, any amount of wheelspin and they instantly lost all lateral grip. Not progressive at all... Dunno what you can get for more trackworthy tires, but you might consider something like RE71R, A052, RT660, ZIIIor if Michelin is preferred, Pilot Sport Cup 2? RE bushings, I havent done much with my BRZ there, just polyurethane inserts for the rear subframe, which helped a bit with left/right transitions. Pretty happy with it as it is for street/track at the moment but may get poly front control arm bushings before next track season... |
#18 |
Drives: 2016 Scion FRS
For what it is worth, I took "stepping on the gas" as basically going full throttle with the wheels turned. That is always going to cause the car to step out. If the car is too loose, feeding throttle while unwinding the wheel, then that is a different story.
Personally, I run about .16 rear toe in. My setup is 245/40/17 A052's on 17x9's, about -3.7 up front zero toe, - 2.2 rear, 7k/7k springs. And the car tends to range from really good to slightly too loose on corner exit. I've never ran 0 toe in this car, but I think it would be diabolical with 0 rear toe. |
| The Following User Says Thank You to steverife For This Useful Post: | gpvecchi (12-16-2020) |
#19 |
Thanks everybody, I found some experience even on the UK forum, and it seems that rear toe in is the culprit. I now have to decide if 0.1 or 0.15 deg per wheel.
#20 |
I should add that my .16 is toe rear toe, so about .08 per side.
I wouldn't go over .1 per side. |
#21 |
Drives: BRZ 2018
#22 |
BAE
Drives: Asphalt FRS
The Michelin PSS i ran always have this issue. Problem goes way when i run my 200TW tires. I accepted that it's just a tire grip issue and moved on.
| Rear Rotor Suggestions? | iLaw | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 10-30-2015 04:07 PM |
| Looking to upgrade rear sway bar, any suggestions? | Str8Ghostin | Tracking / Autocross / HPDE / Drifting | 8 | 02-22-2015 11:40 AM |
| Next Mod Suggestions | bunches7399 | BRZ First-Gen (2012+) — General Topics | 5 | 09-05-2014 11:43 AM |
| Rear Hand Hold Suggestions? | Captain Snooze | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 03-16-2014 03:27 AM |
| FR-S rear license plate frame suggestions? | tzhu07 | Scion FR-S / Toyota 86 GT86 General Forum | 58 | 03-12-2014 03:36 PM |
