Old 12-11-2020, 04:13 PM   #1
EB86
Drives: GT86
Sway Bar Brace, Worth it?
Hi
Has anyone fitted a pair of sway bar braces in isolation and noticed any difference?
The rear sway bar mounts seem to only be supported from the top and could in theory flex if they are stressed in a direction other than down, is there any inherent issue that needs to be addressed by these after market companies?
The blue Superpro (2nd and last image) brace looks like it might flex itself and not provide much support but i'm no engineer, and thoughts?
Does anyone have any experience of Superpro, Cusco, Summit braces?
EB86 is offline   Reply With Quote
Old 12-11-2020, 04:29 PM   #2
ZDan
ZDan's Avatar
Drives: '23 BRZ
Structural engineer here. Without having done any analysis, based on a cursory glance I'd say those swaybar braces are doing very little if anything...
The Following 4 Users Say Thank You to ZDan For This Useful Post:
EB86 (12-11-2020), Icecreamtruk (12-13-2020), strat61caster (12-12-2020), therealstoly (12-16-2020)
Old 12-11-2020, 05:00 PM   #3
Ohio Enthusiast
Drives: 2018 BRZ
Not an engineer, but I agree they don't look to be able to resist anything. They have a long arm which multiplies the torque they need to resist, which is being resisted solely by the weld at the "cup".
I would say an angular brace from the lower mounting bolt of the sway bar mount to the subframe bolt would be more beneficial, but obviously it would interfere with the additional cross brace they have there.
Ohio Enthusiast is online now   Reply With Quote
The Following 2 Users Say Thank You to Ohio Enthusiast For This Useful Post:
EB86 (12-11-2020), therealstoly (12-16-2020)
Old 12-11-2020, 10:19 PM   #4
grumpysnapper
grumpysnapper's Avatar
It’s a beautifully expensive way of adding weight combined with pretty colours, and the added benefit of zero functional gain.
grumpysnapper is offline   Reply With Quote
Old 12-11-2020, 10:58 PM   #5
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
That's my thing with all these braces, I know a cool dude did a thread recently with the braces he likes but I don't think I've seen a single scientific test of the common braces for this car. If I'm gonna spend hundreds of dollars and add weight I'd like to know for sure if they will make a performance difference, and which do it the most.
Plumbus is offline   Reply With Quote
Old 12-12-2020, 04:21 AM   #6
EB86
Drives: GT86
I see what you are saying Plumbus, I am very open to the idea but like to get feedback first, or in the case of grimmspeed specific data. I'm not really an 'anti brace' person, and would like to think I understand why manufacturers don't do these things from the factory, be it cost or NVH issues. However some braces to my untrained eye might add value and support well and others I struggle with, like these sway bar braces.
I have in the past had the grimmspeed front brace and it did what they said it did exactly, but it actually had such an effect on the steering feel in specific situations that it was strange so I sold it on.
Old 12-15-2020, 09:02 PM   #7
Ernest72
What are you trying to do? A brace should solve a problem. I would not waste a ton of money adding braces, but research and maybe add ones that people think helped do something. But that is likely butt dyno so be skeptical. Testing would be nice but the small change in chassis stiffening would be difficult to show except at the extreme. The weight is minimal unless you add every brace. Try them ,if they do nothing sell at 75% cost and call it a day.
Old 12-16-2020, 08:43 AM   #8
steverife
Drives: 2016 Scion FRS
If your sway bar isn't bound, there shouldn't be a lot of force there. If performance is the goal, make sure your bars move freely.
Now if you think it looks cool, then go for it...
steverife is offline   Reply With Quote
Old 12-16-2020, 02:00 PM   #9
HaXx
Drives: jrsc_brz
you have my attention
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
Old 12-16-2020, 02:04 PM   #10
marco_mc22
Drives: Toyota 86
I think the only braces that actually make some "feeling difference" to the steering wheel are the front strut bars + crossmember brace, front end become a little more direct, for the rear there are other things I would change first, like the whiteline insterts.
Anyway, if I could go back, I would save as much bucks as I can for better coilovers before getting into these kind of mods
marco_mc22 is offline   Reply With Quote
Old 12-16-2020, 02:24 PM   #11
Another way of considering the issue is by asking (thought experiment) why the sway bar mount points are so flimsy in any direction except vertical. The answer is because they don't need to be any stronger.
Old 12-16-2020, 02:59 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Why are they bracing in a direction the subframe is already extremely rigid.
Old 12-16-2020, 03:08 PM   #13
AND the sway bar already floats axially. Instagram likes?
Old 12-16-2020, 03:19 PM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I think I am just going to head off the issue and remove the sway bar.
Are sway bars worth it? kev0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 75 02-16-2022 11:41 PM
FS: GTSPEC SWAY BAR REINFORCEMENT BRACE (REAR) andy86 Brakes, Suspension, Chassis 0 11-08-2017 01:20 PM
FS: GTSPEC rear sway brace GTS-SUS-1464 FlashEngineer Canada Classifieds 10 10-04-2015 07:34 PM
sold all Whiteline Rear sway brace also dc Sports lateral brace stiboost08 Brakes, Suspension, Chassis 25 07-19-2015 08:49 PM
Brembo Front Brakes, APR Brake Ducts, GT Spec Rear Lower T Brace/Sway Brace, etc smellslikecurry Brakes, Suspension, Chassis 27 08-15-2014 12:52 PM
