#29 | |
Drives: Track preped NA FRS
The car is very low compared to stock (1 to 2", cant remember how much exactly but low enough) and still is on stock axles. I've gone thru wheel bearings on all 4 corners already, but axles are fine. Main difference here is that my car is very stiff compared to yours, so it probably is more because you bottom out that because you are lowered or the bumps in the road. |
| The Following 3 Users Say Thank You to Icecreamtruk For This Useful Post: |
#30 | |
Axle failures on CTRs are quite common at the track. However, I bet, if you ran the stock tires, you wouldn't break axles :p |
#31 | |
Drives: 2017 BRZ PP WR Blue
Ps-I broke the first axle on the stock tires. But no, you are right… I should expect to have to buy 800 ***TORQUE*** axles from DSS just to do HPDE on street tires at stock ride height with stock dampers and 100 torques 🤪 |
#32 |
It seems no amount of examples will change your mind.
If you broke your first axle on stock tires... you may need to re-examine what you're doing, whether it's how your driving or setting up. We'll agree to disagree. |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#33 | |
Drives: Subaru BRZ
Sent from my SM-G973F using Tapatalk |
#34 | |
Weight Weenie
Drives: 15 FR-S
Nice driving. Did you change your gearing? |
#35 | |
How dare you even question his ability to setup a car. That can't be it at all, clearly. It's not like a hit curbs every single time, have a lowered car with stickier tires and aero that for sure will put more load on a car and not have to deal with breaking axles. ...oh wait.
Kyle H. - #89 STX
| The Following User Says Thank You to M0nk3y For This Useful Post: | Jdmjunkie (12-10-2020) |
#36 | |
Thank you! I only changed the final drive to a 4.88 and the car is only on headers + tune power wise. Lots of mods to suspension and aero, but drivetrain is pretty stockish. |
| The Following User Says Thank You to Icecreamtruk For This Useful Post: | new2subaru (12-10-2020) |
#37 | |
Weight Weenie
Drives: 15 FR-S
I like the way the 4.88 keeps you in the power band. The extra shifting is not too much? |
#38 |
Drives: 2013 WRB BRZ 6MT
Of course, anyone can have an axle or any other part of a car fail on them, even someone driving on the street on OE tires like a grandpa could still be subject to a failure. That's just life.
Being worried about breaking axles myself, knowing that replacements are going to cost me $300 each because of where I live in the world, I've followed the reports pretty closely and there are certain patterns to the failures. The vast majority of failures are on boosted and lowered (more than 1 inch) track cars. NA cars lowered no more than an inch seem to have far fewer failures, to the point that despite the fact that cars in this category *vastly* outnumbers boosted/lowered cars, there still seems to be fewer such reports in total. The prevailing suspicion was that the CV joints aren't designed for the torque that a boosted motor provides and lowering beyond a certain point puts the axle at an angle that puts more stress on the CV joint causing it to be subject to premature wear. Of course, other things can factor in as well. YMMV but if you are NA and no more than an inch lowered and experience axle failure, I'd just assume you were unlucky with the original and tell you to get another OEM axle and save your money. If you are lower, running stickier tires or boost, then investing in a DSS axle might be a plan. Last edited by Lynxis; 12-10-2020 at 09:27 PM. |
| The Following User Says Thank You to Lynxis For This Useful Post: | CSG Mike (12-10-2020) |
#39 |
Drives: Miata
#40 |
Drives: Nevermorange FRS
I’m low, I suspect lower than most and my springs are the eibachs (not too stiff), I’m racing on hoosiers yetI’ve solved the axle thing.
Not sure why it’s such a difficult puzzle. Keep the heat out of it, put in the good grease and let it breathe.
SCCA T4 - FRS
#41 | |
I should mention thought that they lasted me 130k, and I bought 2 used ones for $185. |
#42 | |
I've used several tires, depending on class im racing for and points allowance for each type of tires. On both those videos I was on RE71R. I've used, nittos NT01, Toyos R888R, Maxxis RC1, Yokohamas A052, Continental Sports DW and Nankang AR1. |
| The Following User Says Thank You to Icecreamtruk For This Useful Post: | new2subaru (12-13-2020) |
| Buying an early build in the fall, but some issues with these cars are worrying me... | RyMi | BRZ First-Gen (2012+) — General Topics | 34 | 02-27-2019 09:56 PM |
| LCA Upper Ball Joint Issues (maybe?) | NAEightySix | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 11-03-2017 01:31 PM |
| AVO owners who HPDE/Track... Any issues? | seven | Forced Induction | 11 | 01-19-2015 11:15 AM |
| New cars produced still suffering from first year issues? | Lord09 | Issues | Warranty | Recalls / TSB | 30 | 09-22-2013 07:32 PM |
| Brake issues on the track | Mike @ MRP | Tracking / Autocross / HPDE / Drifting | 28 | 08-30-2013 05:03 PM |
