Old 12-01-2020, 11:12 AM   #1
Nick826
Drives: slowly getting there
how close is too close?
not sue if this should go into the wheel categories or suspension. right now I have Bilstein b 14 coils and a 18x9.5 +35 on a 235/40. because of the progressive spring rates on the Bilstein, at the thickest part of the spring comes about 1/4 inch from the wheel. Is this too close and will I destroy my suspension or wheels?
and how low do these coilers go. lmk if you have any experience with fitment this close. thanks
Nick826 is offline   Reply With Quote
Old 12-01-2020, 11:42 AM   #2
Joveen
Joveen's Avatar
Drives: Bone stock
235 on 9.5 is a lot of stretch my guy.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 12-01-2020, 11:43 AM   #3
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
1/4" is plenty of clearance imho
I never tried to slam mine, the lower you go the more bump stop you use and the suspension becomes more uncomfortable, iirc I set them around 1"-1.5" lower then stock.
ineedyourdiddly
Nick826 (12-01-2020)
Old 12-01-2020, 12:38 PM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
3mm would be my min static clearance, 1/4" is 6+mm, IMO you're OK.
FWIW 235/40-18 is okeedokee on 18x9.5, it's the max recommended wheel width. Would be a "stretch" on 10"....
The Following 2 Users Say Thank You to ZDan For This Useful Post:
Nick826 (12-01-2020), RToyo86 (12-01-2020)
Old 12-01-2020, 01:01 PM   #5
Nick826
no not at all. its actually perfect. some guys run a 225/40
Old 12-02-2020, 03:23 AM   #6
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
235/40 on 18x9.5 is a bit of a stretch. I run 235/40 on 18x8.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 12-02-2020, 07:30 AM   #7
ZDan
ZDan's Avatar
Drives: '23 BRZ
The wheel width range to run a 235/40-18 is 8" up to 9.5". So that tire size on 8" or 9.5" is legit, just at different ends of the envelope.
For maximum lateral grip and responsiveness, you would want to be at the wider end of the wheel width range.
Personally, I'd run 245/35-18 on 18x9.5", and I'd run 225/40-18 on 18x8.
Old 12-02-2020, 08:38 AM   #8
Nick826
my stretch is fine. looking to see if you guys have personally ran something this close. my wheels poke aswell and think camber bets would make my clearance even closer. would camber adjustable top hats solve this ?
Old 12-02-2020, 10:21 AM   #9
Nick826
A photo of the stretch. Very mild
Old 12-02-2020, 01:33 PM   #10
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
So you would run a 1 1/2" wider rim and increase the tire by 3/4"
Old 12-02-2020, 01:44 PM   #11
ZDan
ZDan's Avatar
Drives: '23 BRZ
We have both guy A and guy B running 235/40-18 tires, one on a 9.5" wide wheel and one on an 8" wide wheel.
All I'm saying is if I'm "guy A", I'd be running 245/35-18s on his 9.5" wheels, and if I'm "guy B" I'd be running 225/40-18 on his 8" wheels.
But they're both OK with 235/40-18, although they are slightly larger in diameter vs. stock size, not a biggie...
gen3v8 (12-02-2020)
(Close)WTB:Aus GT Black interior(Close) Ry.ruzn Want-To-Buy Requests 0 04-20-2016 01:55 AM
How close is too close?: Gap between tire & spring perch kodyo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 09-20-2015 01:32 PM
CLOSE/DONE Jman1759 Want-To-Buy Requests 2 07-22-2015 02:58 PM
Please Close. dizzario Wheels and Tires 1 05-11-2014 10:40 PM
End. Close please Figo NY / NJ / CT / PA 7 05-09-2014 01:32 PM
