Old 08-07-2020, 12:03 AM   #85
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Originally Posted by mauly View Post
I recently installed a 2017 A/T engine (black manifold) into my 2016 a/t brz. I transferred every single sensor and the complete wiring harness from my 2016 engine, to my new 2017 engine. The car starts and runs okay for a minute but then gives me P0011 and P0021 CEL (timing over advanced) Do i need a different tune for the 2017 engine to run correctly?
No, you need to pull the front cover off and swap over the cam trigger wheels off the older engine. Each wheel is specific to each camshaft. Turn the engine over by hand until the triangles face each other before swapping. 3 inverted torx bolts each, sorry I don't remember the size off the top of my head. I want to say they go to 12-13ft-lbs, but, please double check.
The Following User Says Thank You to Kiske For This Useful Post:
T-Steve (11-12-2021)
Old 08-07-2020, 12:39 AM   #86
D-VO
Drives: Whiteout FR-S, Evo 8 RS
Attachment 191142
You dont have to take the cam gears apart, you can simply switch the cam gear itself.
D-VO is offline   Reply With Quote
Old 08-07-2020, 01:08 AM   #87
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Yeah, I was just thinking if he was going to be doing it with the engine in the car still it would be easier to just swap the wheels themselves. That way he doesn't have to mess with the pulling the chain and messing with that bit, saving a bit of time.
Old 08-07-2020, 03:51 PM   #88
mauly
mauly's Avatar
Drives: 2016 BRZ Limited
I wouldn't chance it because I'm not 100% certain. However, I had a Subaru technician directing me through most of it who told me I need to, so I trust him. It's something about the sensors that I inside the cam gears.
EDIT* okay just had a chance to talk to him again. He says;
Plastic manifold 17+ engines will bolt right up pnp but aluminum intake manual trans engines need to swap cam gears and trigger wheel. They send a completely different signal.
Subaru technician said 17 plastic manifolds dont need to swap cam gears though, thats what im trying to find out before i pull timing cover off
mauly is offline   Reply With Quote
Old 08-09-2020, 11:58 PM   #89
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Pull one of the top cam sensors out then, peek through the hole. That should tell you what you have at least.
Old 11-10-2020, 12:03 AM   #90
o1gnah
Drives: Argento Metallic
The ZC engine was in my first civic hatch. 👍
Originally Posted by Vracer111 View Post
Wondering drop in compatability as well, but my plan is to get a used motor and hand build it to spin up faster and have an 8krpm top end. Enhanced valve train compenents, Carillo H-rods, ARP hardware, good gaskets, and sealed up really well with RTV/bonding material to prevent valve cover leaks. Block and heads is what really matters to me anyways...intake can stay the same. A newer engine would be better, but don't think much has changed with the block and heads that would really effect anything...swap over sensors and intake to newer block/head and should be no issues. Did a ZC swap on a CRX Si years back that was pretty straight forward...not bad at all going to the DOHC motor from the stock SOHC one, very minimal wiring changes...
o1gnah is offline   Reply With Quote
Old 11-25-2020, 04:53 PM   #91
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
did you ever get this straightened out? Try to confirm if a MY17+ AT engine is more direct swap than the MT
Old 12-29-2021, 12:52 AM   #92
remix1041
remix1041's Avatar
Drives: brz
What if I swap 17 engine into 13 with 17 ecu and harness. Will it work? Anyone know?
remix1041 is offline   Reply With Quote
FS: 2013 FA20 engine w/spun bearing Bullnettles Engine, Exhaust, Bolt-Ons 9 04-05-2017 07:39 PM
FS: FA20 Engine Sportsguy83 Engine, Exhaust, Bolt-Ons 12 03-01-2017 03:51 PM
2017 engine vs 2013 engine DailyDriver86 Engine, Exhaust, Transmission 17 11-09-2016 06:16 PM
Looking to buy FA20 engine ndreim Want-To-Buy Requests 0 12-15-2015 07:06 PM
FA20 Engine Wins Ward's 10 Best Engines of 2013 Jeffsu350 Scion FR-S / Toyota 86 GT86 General Forum 111 03-15-2015 04:39 AM
