Old 11-08-2020, 07:57 AM   #1
SCFD
OEM Headlight Glare
I have a 2020 BRZ and found that the headlights have good light output -- maybe too good.
I frequently drive on unlit rural roads in the evening and have noticed a large number of people flashing their high beams at me. Anybody experience this with their stock BRZ headlights?
There was another BRZ behind me one evening and I did notice the stock headlights seem to produce a lot of glare. Never thought I'd say this but I'm at the point where I'm thinking of throwing tint on the headlights so I don't keep blinding oncoming traffic.
SCFD is offline   Reply With Quote
Old 11-08-2020, 08:18 AM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Step 1, make sure they are aimed correctly.
IDK what is up with manufactures today, but just about every new car a family member has gotten needed the headlights adjusted.
The Following User Says Thank You to x808drifter For This Useful Post:
Spuds (11-08-2020)
Old 11-08-2020, 12:20 PM   #3
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
I've gotten a lot of the same on my 86. I haven't checked the aiming of the headlights, but it's probably worth a look.
Cephas is offline   Reply With Quote
Old 11-08-2020, 05:39 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
The BRZ has motorized adjusters. Were they set right?
The official spec is 2" drop every 35'. I usually just get mine so they're completely flat, or just under depending on vehicle loading conditions
Spuds (11-08-2020)
Old 11-08-2020, 08:17 PM   #5
SCFD
I'm hoping they are since I just bought the vehicle new off the dealer lot. How do you set headlight cut off on the BRZ with motorized adjusters?
Old 11-08-2020, 09:38 PM   #6
soundman98
soundman98's Avatar
this knob:
the higher the number, the lower they go.
Old 11-08-2020, 10:11 PM   #7
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
this knob:
Wait! That's a thing!?!?
Old 11-08-2020, 10:50 PM   #8
SCFD
this knob:
Thanks. It appears I'm missing that knob so I'm assuming I have manual headlights.
I bought a base model without the heated seats and dual-zone climate control so I guess it also doesn't come with fancy motorized headlight adjusters.
Old 11-08-2020, 11:01 PM   #9
NaturallyAspirated
NaturallyAspirated's Avatar
Drives: 2019 BRZ w/ PP
The 2017+ BRZs (probably the 86 as well) with LED headlights don't have the adjustment knobs. They're "automatically" leveled using a sensor mounted on the rear lower control arms.
NaturallyAspirated is offline   Reply With Quote
The Following 2 Users Say Thank You to NaturallyAspirated For This Useful Post:
soundman98 (11-09-2020), Tcoat (11-09-2020)
Old 11-08-2020, 11:01 PM   #10
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
Try this thread: https://www.ft86club.com/forums/showthread.php?t=123568
2020BRZtS is offline   Reply With Quote
The Following User Says Thank You to 2020BRZtS For This Useful Post:
SCFD (11-08-2020)
Old 11-09-2020, 12:03 AM   #11
soundman98
soundman98's Avatar
All of the oem hid models had it. One of the things that reinforced my choice to buy a BRZ over an fr-s
Old 11-09-2020, 01:16 AM   #12
Spuds
The Dictater
Spuds's Avatar
Do you use it often?
Old 11-09-2020, 05:57 AM   #13
Only until 2016.
Old 11-09-2020, 09:12 AM   #14
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
If you have fog lights turn them off. I don't run mine in rural areas or I get flashed.
First only left headlight works, then only right headlight russsak Cosmetic Modification (Interior/Exterior/Lighting) 2 09-23-2020 04:05 PM
BRZ headlight shroud inside FRS headlight? S84kam Cosmetic Modification (Interior/Exterior/Lighting) 9 04-02-2016 01:24 AM
Product To Reduce Dash Glare? Captain Snooze Cosmetic Modification (Interior/Exterior/Lighting) 12 08-20-2015 07:55 PM
Tinting mirrors to reduce nighttime glare Assphalt Cosmetic Modification (Interior/Exterior/Lighting) 38 03-27-2015 09:48 AM
WTB Stock headlight projectors from retrofit OR a broken headlight official_george Exterior Parts (Aero, Lighting, Etc.) 3 12-02-2013 04:32 PM
