Old 11-08-2020, 08:33 AM   #1
ThaDonJsuan
Drives: 2020 Subaru BRZ Sport-tech
Storing Track/Street tires in the winter
Hey all,
What do you guys do with your track tires for the winter?
For the Hankook RS4 the manufacturer says the tires cant flex if below freezing temperature or it may cause irreversible damage. IS it OK to keep them on the car over the winter as long as they aren't driven on?
ThaDonJsuan is offline   Reply With Quote
Old 11-08-2020, 08:44 AM   #2
SCFD
Proper winter storage is important for any summer tire. Is your car parked outdoors or indoors? It'll probably be fine even in a non-heated garage but they'll definitely be permanently damaged if your car is sitting outside.
SCFD is offline   Reply With Quote
Old 11-08-2020, 10:37 AM   #3
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Originally Posted by ThaDonJsuan View Post
Hey all,
I always remove my track wheels/tires and keep them inside my house during the winter. It is pretty critical so that the tires don't prematurely crack. Even if they don't crack, I've always found them to be slower the next year if they are stored in the cold.
Do you have them on an extra set of wheels? If so, just bring them inside for the winter.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 11-08-2020, 04:29 PM   #4
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
Tires should be stored in a cool, (read temperature controlled) dry location out of direct sun light. The problem with storing tires in an unheated garage or outside is the temperature fluctuations. If you leave them on the car jack the car up off the ground to take the weight off.
Old 11-08-2020, 05:11 PM   #5
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
I live in Florida, we do track days all year. Problem solved.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 11-10-2020, 03:34 AM   #6
SUSPECT_BRZ
SUSPECT_BRZ's Avatar
Drives: 2020 Subaru BRZ TS
I have always stored my cars in a non-heated garage and never encountered any issues. Always left the vehicle parked on the floor. Both with regular tires and track tires.
SUSPECT_BRZ is offline   Reply With Quote
The Following User Says Thank You to SUSPECT_BRZ For This Useful Post:
Tcoat (11-10-2020)
Old 11-13-2020, 08:45 AM   #7
dodj
Drives: Rallye Blue BRZ
When left on the floor and stationary I will increase the inflation pressure of the tires.
dodj is offline   Reply With Quote
Street tires for some track use Tristor Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 08-06-2018 05:26 PM
Looking for street/track tires for next year. Lynxis Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 08-26-2016 10:42 PM
Storing 200 treadwear tires over the winter Thrustin Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-28-2015 12:23 PM
Drain STA-BIL gas after storing for winter? 1Cor10:23 CANADA 31 02-26-2015 03:17 PM
When to replace street tires used for the track? ayau Tracking / Autocross / HPDE / Drifting 4 07-23-2013 12:45 PM
