Old 09-27-2020, 02:30 PM   #85
cliddell
Drives: Toyota GT 86
One other silly question:
The "lever lock" on the connector: does unlatching it mean lifting from the bottom and swinging upwards?
I ask because, if that is correct, mine is decidedly reluctant to move, and I'm reluctant to more force into it without being absolutely sure.
Ideally, if someone is willing/able to post a photo of the lever in the open position, that would be very much appreciated!
cliddell is offline   Reply With Quote
Old 09-27-2020, 04:58 PM   #86
norcalpb
norcalpb's Avatar
I believe there is a push tab on the lever itself you need to push on while pulling said lever.
It says “press” on it right below the Bosch logo.
Edit: also you may need to remove a white zip tie holding the assembly together
Old 09-28-2020, 04:25 AM   #87
cliddell
That's fab, thank you!
The Following User Says Thank You to cliddell For This Useful Post:
norcalpb (10-02-2020)
Old 10-10-2020, 01:10 PM   #88
cliddell
I got my VSC ECU swapped on my 2015 UK car this afternoon, and the difference is pretty awesome.
But just to add some confusion, my car is an early 2015 (manufacture date February 2015, IIRC) which I figured *should* make it a 2014/2015 model year, and I'd need to do the repin. But on closer inspection, I did not.
Thanks to all those who put in the legwork on this mod, it's definitely worth doing, in my opinion!!
MJones_RB (10-12-2020)
Old 10-11-2020, 10:58 PM   #89
blown
Drives: ft86
I didnt see, how do you activate track mode with 2013 buttons/dash?
blown is offline   Reply With Quote
Old 10-12-2020, 02:09 AM   #90
churchx
churchx's Avatar
Drives: 2014 GT86
You activate track mode just like VSC sport, just pressing slightly longer (1s?). And it won't display track but vsc sport on dash obviously.
You can also activate now hill assist, but it won't have it's indicator on older dash.
Old 10-13-2020, 03:25 PM   #91
norcalpb
norcalpb's Avatar
Track mode wasn't enough to save my ass on wet pavement with cold tires
The Following 3 Users Say Thank You to norcalpb For This Useful Post:
bhmax (11-07-2020), NoHaveMSG (10-13-2020), solidONE (11-10-2020)
Old 11-07-2020, 07:42 PM   #92
bhmax
Drives: 13 BRZ, 17 Focus RS
Thanks for this, wish I had seen it months ago when it was first posted! This excites me, as I love to tinker and have never been happy with the stock VSC on my ‘13. I’ve never been able to tell a difference between normal and sport, but they both have always responded way too early and abruptly for me. However, I’ve had the once a year upset on the street usually due to water or debris where it has probably helped me. Due to this, I don’t want to be full off on the street, especially on spirited drives with cliffs past the edge of the road. The only other car I’ve owned with VSC is a Fiesta ST, and even during AX if it’s reacting, it’s doing it so smoothly I can’t tell.
For track and a couple of drift days I’ve done, 3 second off has worked perfectly fine for me. The only thing I don’t like is the lights still flashing on the dash when it thinks it should be helping me. I’m curious if this will still be the case with the newer module? I’ve used the pedal dance a few sessions, but the only thing I noticed was unstable braking. I’m sure different skill level, brake setup, alignment setup could change that.
It looks like there’s plenty of these modules on eBay, but quite a range in price. Looks like currently the cheapest is around $250. I think I may have found one elsewhere for around $125. What have you guys been paying for them?
bhmax is offline   Reply With Quote
Old 11-09-2020, 02:41 PM   #93
sroby
Drives: 2015 Firestorm 08/05/15
Originally Posted by Yoshoobaroo View Post
BRZ/86 doesn't matter. I swapped a 2019 86 module in my 2013 BRZ.
Manual vs Auto is trickier. We're not sure if it actually makes a difference -and most of us suspect it doesn't- but everyone that has done the swap so far has played it safe. Most eBay listings will tell you the specs of the donor vehicle. If you feel like being the guinea pig to swap an auto module into a manual, we could learn if it matters or not. If you have a 13-14 that needs a repin I can send you a manual 2015 module so you can swap that in case the auto module doesn't work. This way you wouldn't have to undo the repin while waiting for another module and your car isn't out of commission.
Deleted
sroby is offline   Reply With Quote
Old 11-09-2020, 02:52 PM   #94
sroby
No wires present, just a rubber plug in the hole.
I got mine from 417motoring too. They're good, they sent it to me twice cause Fedex is useless and sent it back to them.
Ballpark what this unit will cost plsr thx in advance
Old 11-09-2020, 04:27 PM   #95
gpvecchi
gpvecchi's Avatar
Originally Posted by sroby View Post
So to be clear on my slow senior senile mind��, I will only need to find an abs module the black brain box from a 2017-2019 (86) or brz manual to work on my late production year 2015 manual FRS. I don’t need the Aluminum portion? Or does the aluminum block portion come with the module usually from a salvage yard plsr. Thx in Advance Steve
You need just the black part, no aluminium portion...
But salvages usually sell them together.
The Following 2 Users Say Thank You to gpvecchi For This Useful Post:
jflogerzi (02-20-2021), sroby (11-09-2020)
Old 11-09-2020, 04:45 PM   #96
sroby
Gotcha my friend. Thx so much and best regards.
The Following User Says Thank You to sroby For This Useful Post:
gpvecchi (11-09-2020)
Old 12-01-2020, 09:51 PM   #97
caffeinejunky
hella stock
caffeinejunky's Avatar
Drives: BRZ Limited
Welp. So I tugged too hard () and managed to pull the wire off with the connector still in the harness. Lesson learned..
https://imgur.com/W7V7kvB
Anyone know what crimp kit I should get to get a pin back onto this thing so I can insert it back onto the harness?
mods & accessories:
beat-sonic shark fin | raceseng apex r limited green | perrin intake | E85 | RS*R Super Down sus | Cleib CF Lip | STi Side Skirts | Rays Gram Lights 57DR
caffeinejunky is offline   Reply With Quote
Old 12-02-2020, 10:09 AM   #98
Racecomp Engineering
Originally Posted by solidONE View Post
LeeC Parts know how to pick the 86's. I'm a custmers as well. Recomend this guy.
I randomly drove by LeeC parts this summer. Completely unexpected and not as interesting for my girlfriend as it was for me.
- Andrew
bhmax (12-02-2020), solidONE (12-03-2020)
Review of "Track Mode" on the MY17+ cars trippinbillies40 Tracking / Autocross / HPDE / Drifting 85 02-22-2021 10:27 PM
FS: Nameless muffled track pipe 2013-2016 Dave-ROR Engine, Exhaust, Bolt-Ons 4 05-21-2020 12:27 AM
Track mode vs. VSC sport alex87f Scion FR-S / Toyota 86 GT86 General Forum 9 10-30-2018 11:47 PM
2017 Track mode on older model Bobster Engine, Exhaust, Transmission 17 12-03-2017 11:34 PM
