Old 11-01-2020, 06:10 AM   #1
jflogerzi
jflogerzi's Avatar
Upgrade 2013 to newest coil pack design and connectors
I know the early cars had issues. I am getting ready to remove my super charger to prepare for smog and might as well take care of a few things on the car above the manifold will be off
OEM spark plugs
New front O2 sensor
Newest oem coil packs and connectors
Any have part numbers to do this. Car is 2013 and has almost 73k on the odo. Might as well do these all in one shot.
2013 Series 10 FRS #553
Old 11-02-2020, 01:11 PM   #2
Grady
Grady's Avatar
You could do the Delicious coil packs. Better design same old connector.
Old 11-02-2020, 10:29 PM   #3
jflogerzi
jflogerzi's Avatar
I thought part of the problem was the connection more so than the coil itself
Old 11-07-2020, 04:13 PM   #4
Project_1796
Drives: Scion FRS 10 series
I just did the conversion myself here are the part numbers, also the coolant temp sensor and oil temp sensor have different style plugs, you will need to swap connectors or get 2016+ sensors
HARNESS-ENGINE. 24020AG080
COIL ASSEMBLY-IGNITION. 22433AA730
OEM spark plugs
New front O2 sensor
Project_1796 is offline   Reply With Quote
ISO coil pack connector pigtail thE_iyE Want-To-Buy Requests 1 09-22-2019 02:52 AM
Coil Pack upgrade 2015 BRZ Mad-BRZ BRZ First-Gen (2012+) — General Topics 2 04-14-2019 12:53 PM
Coil pack options ROADRACER Engine, Exhaust, Transmission 14 12-24-2018 03:33 AM
Coil ignition pack D86Ellis Issues | Warranty | Recalls / TSB 7 09-20-2016 03:01 AM
Coil pack part numbers? feldy Engine, Exhaust, Transmission 6 03-11-2014 12:31 PM
