Old 10-15-2020, 02:28 AM   #43
yzf219
Drives: 2013 FRS GTX3076R
Originally Posted by TommyW View Post
that is probably too close once the tire starts moving around a bit in turns. You'll most likely rub.
Yea, I am scared of that too, gonna put some masking tape on the strut and take it for a test drive to see if it rubs.
Sent from my SM-G950W using Tapatalk
yzf219 is offline   Reply With Quote
Old 10-15-2020, 06:46 AM   #44
54fighting
Drives: 2020 toyota 86
Originally Posted by RToyo86 View Post
Pedders top mounts are an option.
do you have a link for this?
Thanks
54fighting is offline   Reply With Quote
Old 10-15-2020, 01:22 PM   #45
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by HaXx View Post
Heres what i would have you do
keep the bottom oem bolt in the bottom hole, and put the camber bolt up top and push the top of the wheel in.
I have learned a fair amount about how people run double digit camber. while we are idiots, we're not stupid. they ALWAYS anchor the bottom hole with the bottom oem bolt. you dont want 2 sketchy connections. people running big camber will get their adjustment from the top hole, either slotting inward, or in your case with a camber bolt, but the bottom hole is ALWAYS oem, that is the anchor that we dont mass with.(im not going to bring up FLCA in this thread)
i know some track people use a camber bolt in bottom and skinny crash bolt up top giving you adjustment from both holes but somehow they dont catch flack, realistically its fine, and so is slotted struts, but who am i.
many people do many different things, different bolts in different holes, but i recommend having the bottom be your anchor. hey, im not a fan of slotting struts either, thats why i got the onimade camber plates.
with the oem bottom bolt in the bottom hole, and an eccentric bolt up top, that will give you camber that is appropriate for the ability of most track enthusiasts.
In 150k+ miles I have never had it slip with an upper crash bolt and lower eccentric bolt. I even have a slotted strut for like 100k of those miles. Many on here run the same setup with no ill effect. That doesnt mean they shouldnt be checked regularly. Multiple people have reported slipping eccentric bolts when put in a slotted or larger strut hole like you are suggesting.
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
strat61caster (10-15-2020), yzf219 (10-15-2020)
Old 10-23-2020, 03:09 AM   #46
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
Originally Posted by yzf219 View Post
Can't even imagine what a stiff spring rate would feel like. Yikes.
Weld the shocks solid.
Plumbus is offline   Reply With Quote
Old 10-23-2020, 07:53 AM   #47
bfrank1972
Drives: 2013 FR-S Argento
KWs are slotted. My RCE T2s are slotted (revalved KWs). Works just fine, although takes a little more finesse when performing alignment. Probably should use non-cammed factory crash bolts in the slots.
Sent from my SM-G965U using Tapatalk
The Following User Says Thank You to bfrank1972 For This Useful Post:
Racecomp Engineering (10-23-2020)
Old 10-23-2020, 11:35 AM   #48
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Thanks
https://www.ftspeed.com/part/580096-...u-toyota-scion
https://pedders.com/products/580096-...-camber-caster
Old 10-23-2020, 12:58 PM   #49
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
I slotted my factory strut to get the camber I wanted. It takes very little material removal to produce measurable camber change. I was only able to get around 2 degrees neg up front with camber bolts, so rather than double up or go with smaller diameter bolts, I just did a little measuring and math and only had to remove like 1/8" of material to get the camber I wanted (~2.9 degrees). Once you tighten the bolt, it's not like the strut is going to move around on the hub - the stress from hitting a pothole will just push the bolt against the end of the slot the same way it does against the factory hole. I've slotted the struts on just about every non-adjustable MacStrut front end car I've ever had. ZERO problems. Just be sure to get it re-aligned after reassembly again to fine tune with the existing adjustable bolt you already have. It isn't rocket science or even difficult to do...just get the math right. You might be surprised how small a change at the strut bolt translates at the wheel. Of course, I'm a little old school, and disappointed by how 'enthusiasts' these days are afraid to tackle anything that isn't 100% bolt-on...
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Last edited by venturaII; 10-23-2020 at 05:50 PM. Reason: Because I'm a curmudgeon...
The Following 2 Users Say Thank You to venturaII For This Useful Post:
grumpysnapper (10-25-2020), yzf219 (10-24-2020)
Old 10-23-2020, 02:28 PM   #50
TunaNoCrust
TunaNoCrust's Avatar
Drives: 86, 981S, RX8, 2500HD, GenesisV8
I strongly suggest waiting and getting camber plates...they do come up for sale in the classifieds here fairly often. I got mine from here, put new bearings in and race the hell out of them! I am running Verus camber plates and an SPC camber bolt for -4 up front.
TunaNoCrust is offline   Reply With Quote
The Following User Says Thank You to TunaNoCrust For This Useful Post:
yzf219 (10-24-2020)
Old 10-23-2020, 03:52 PM   #51
bfrank1972
FYI negative camber with plates will lower your roll center, haven't figured out how big the impact is on our cars (i.e. -3 via plates vs -3 at the knuckle) but something to keep in mind, especially if your car is already lowered and close to the threshold where bump steer can become noticeable.
yzf219 (10-24-2020)
Camber Bolt Options? Maverick986 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 04-05-2018 12:10 PM
Top mount/camber plate options for KW V3? owenxguo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 05-21-2014 11:28 PM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 01:53 PM
Color options Camber Plates, Stress Bar, & Shock Mounts GC_Adam Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 03-26-2013 02:08 PM
Rear camber adjustment options? zooki Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 09-12-2012 11:46 AM
