#169 | |
Drives: 2020 GMC Canyon Denali Diesel
Code Monkey's car was very neutral, stable and had a lot of grip. Very similar levels to my RCE setup and just a tad bit firmer. MCS makes a nice coil over!
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
| The Following User Says Thank You to Opie For This Useful Post: | Code Monkey (07-09-2020) |
#170 |
Drives: Subaru BRZ
A while ago the transmission started to act again during a road racing session. I had trouble going into gears and had to end my weekend early. Upon inspection, the clutch was shot and there were metal flakes in the tranny. The garage space is taken up by another project at the moment so I had the Atlanta Speed Company perform the work. I usually avoid shops like the plague, but these guys are awesome, highly recommended.
Installed: - brand-new 0-mile OEM transmission (previous one was used with 34,000 miles) - new clutch (Southbend stage 2 endurance) - new flywheel - Verus clutch fork and clutch fork pivot - new TOB - swapped MTEC shift springs from the busted tranny Unistalled: - Money Shift Racing hydraulic TOB |
#171 |
Drives: 2023 BRZ
Oooh, tell us more about your decision to uninstall the hydraulic TOB.
Director of Rocky Mountain 86CUP
#172 |
Drives: Subaru BRZ
This is my 3rd transmission so I want to take a hard look at myself and think whether I am doing something wrong. Banging gears too much, dragging the clutch, something else? I wanted to eliminate as many extraneous factors as I can, hence going back to the OEM TOB. The shop said the MSR TOB looks fine, but they recommend a hydraulic TOB for FI cars, not for cars at stock power level.
| The Following User Says Thank You to Code Monkey For This Useful Post: | Pat (10-06-2020) |
#173 |
Drives: Subaru BRZ
Went back to stock header/overpipe/front pipe and removed the Flex Fuel kit. Needed to pass emissions + it is time to simplify things. Got yet another check engine light, this time for the rear o2 sensor; replaced with a new OEM sensor. The code went away after a couple drives and the car successfully passed emissions.
#174 |
Drives: unlimited cheap build N/A track car
What is the preferred tranny lube for track cars these days? I was using Pentosin but changed to Motul 300. I have since started to get a grind going into 3rd. I'm not sure if it is a lubrication or a wear issue.
#175 |
Drives: Subaru BRZ
I have been using Motul Gear 300 75w90 but switched to Redline MT-90 75w90 for the new transmission.
| The Following User Says Thank You to Code Monkey For This Useful Post: | ROADRACER (10-14-2020) |
#176 |
Drives: 2023 BRZ
50/50 mix of Motul Gear 300 and Redline MT-90 is the best I've found.
| The Following 2 Users Say Thank You to Pat For This Useful Post: | Code Monkey (10-14-2020), ROADRACER (10-14-2020) |
#177 |
Drives: Subaru BRZ
Put 500 miles on the new transmission and changed the tranny fluid. The drain plug looks good.
Changed engine oil; 1,911 miles since last oil chage but almost a year ago. Also had the Whiteline diff bushings installed (KDT924) to complement the previously installed KDT922 and KDT923. |
#178 |
Drives: Subaru BRZ
Another oil analysis from Blackstone.
| The Following User Says Thank You to Code Monkey For This Useful Post: | dowroa (11-04-2020) |
#179 |
Drives: 2017 BRZ PP, 2004 WRX
Did a read through of your ownership with this car and tracking it. Christ, the upkeep and wear.
I autocross only (a lot) and think I'll stick to that, lol.
| The Following User Says Thank You to cmiovino For This Useful Post: | Code Monkey (02-10-2021) |
#180 | |
Drives: Subaru BRZ
I just need this engine to last another year or two and then do a K-swap when it goes. ![]() This year I will do some track days in the Civic Type R to spread the wear and tear across two cars.
#181 |
Drives: Subaru BRZ
Removed the Essex harness bar and Schroth harnesses. Kept the original trim pieces so the interior is back to stock.
#182 |
Drives: 2016 Scion FR-S
| Berzerk's 2017 CWP 'Slow and Steady' Build Thread | Berzerk | Member's Car Journals | 12 | 07-24-2017 05:57 PM |
| Rodie's slow '13 FR-S build | rodie | Member's Car Journals | 0 | 06-14-2015 09:05 PM |
| Slow Progression FRS Build | dgerny | Member's Car Journals | 1 | 04-15-2014 07:48 PM |
| Tkalz slow build! | Tkalz | Member's Car Journals | 15 | 10-13-2013 06:35 PM |
| Slow Build by Jooks | jooks | Member's Car Journals | 4 | 07-03-2013 11:53 PM |
