Old 10-06-2020, 12:59 PM   #1
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Extra gains suggestions on N/A
While I save for either turbo or supercharger, I want to get the most (safely) from my N/A setup. Off the bat, E85 is out of the table because it's difficult to get it where I live. I searched, trust me. So far I have:
Inlet Tube with drop in air filter
Lightweight crank, alternator, water pump pulleys
JDL UEL catted (Emissions and headache witching to stock) headers.
Overpipe
Stage 2 Tune OFT
Double resonated FP
Q300 Catback.
Honestly I'm mostly curious to see what people look for to maximize their N/A set ups. This is for educational purposes more than anything.
spcmafia is offline   Reply With Quote
The Following User Says Thank You to spcmafia For This Useful Post:
HaXx (10-09-2020)
Old 10-06-2020, 01:00 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
1.Ditch catted header.
2.Beyond that, boat load of cash for marginal gains.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Atropine (10-16-2020), HaXx (10-09-2020)
Old 10-06-2020, 01:04 PM   #3
spcmafia
spcmafia's Avatar
I cant get rid of them. Though I understand the slight edge from Uncat over Cat, I'm trying to keep my tires from being slashed and tickets. Where I live cops are super anal about it.
Old 10-06-2020, 01:07 PM   #4
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I don't see the value in a pulley upgrade. You'd probably be better off with a lightweight flywheel if you wanted the engine to feel livelier.
Front pipe and catback are basically noise mods. Worth pursuing if you want to tune for sound. Very small to no gains compared to money spent.
The Following User Says Thank You to RToyo86 For This Useful Post:
Windycitystig (10-06-2020)
Old 10-06-2020, 01:10 PM   #5
spcmafia
spcmafia's Avatar
I've seen the debates around pulleys and placebo effect. Ever since I added them I felt a slight increase in responsiveness and more than anything rev matching became even easier. That plus sale and 20% off extra, it was hard to say no.
Old 10-06-2020, 01:13 PM   #6
spcmafia
spcmafia's Avatar
I do agree with the FP and catback. They offer little to nothing. It was mostly for sound. Guilty pleasures we all have.
Old 10-06-2020, 01:32 PM   #7
Grady
Grady's Avatar
Pay for a good custom tune. Put original crank pulley back on and go with light weight flywheel. CF drive shaft is a good way to lose rotational mass. Driver mass reduction works also if it is needed. Don not go wide on tires/wheels go light with good compound.
Old 10-06-2020, 01:36 PM   #8
spcmafia
spcmafia's Avatar
Great suggestion, bit pricey for CF but doable. Never ever will I go wide wheels, camber, lowered set up. Hence my exhaust setup, conservative.
Old 10-06-2020, 02:03 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Why not just put that money towards your boost budget Seems like a better option to me then spending money on marginal gains.
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post:
Atropine (10-16-2020), Lantanafrs2 (10-21-2020), Tcoat (10-06-2020), WildCard600 (10-06-2020)
Old 10-06-2020, 02:03 PM   #10
NoHaveMSG (10-06-2020), p1l0t (10-10-2020), spike021 (10-07-2020), vintagemxer (10-07-2020), WildCard600 (10-06-2020)
Old 10-06-2020, 02:09 PM   #11
This ^
There are loads of things that can be done to the NA engine but none will add up to much more than a header and a tune.
Some will even counter the gains made by others.
The gains made from modes are not just simply adding the claimed rate from one to the next item in a linier manner. It all has to work as a package so adding random bits and pieces is just pouring money don the drain unless you happen to accidently hit the right combination.
The thing is that these cars are already pretty much designed for performance so changing bits out won't give you the same sort of improvement you would get from changing the same part on a Civic LX or a 2001 Neon sedan.
NoHaveMSG (10-06-2020), Windycitystig (10-06-2020)
Old 10-06-2020, 02:16 PM   #12
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
ITBs, stroker kit, and a louder exhaust for placebo effect
MS, CSCS, TSAC-F, CPT
Old 10-06-2020, 02:23 PM   #13
Lantanafrs2
Drives: 2013 frs red
After 7 years of forum threads, it seems that header, tune and e85 are about it. You might be underwhelmed after you get used to it. Driving a stocker at that point will be a good idea just to remind you where you came from
Lantanafrs2 is offline   Reply With Quote
The Following 2 Users Say Thank You to Lantanafrs2 For This Useful Post:
Hades (10-06-2020), Tcoat (10-06-2020)
Old 10-06-2020, 02:39 PM   #14
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
What's the current thought on power blocks for a car that'll stay N/A? Seems some disagreement about them in the threads I've read on here.
Cephas is offline   Reply With Quote
Slim down for ..car gains? Lakitu Off-Topic Lounge [WARNING: NO POLITICS] 33 04-27-2018 01:16 PM
OFT Gains trev616 Software Tuning 14 02-07-2018 12:23 PM
Possible whp gains kjdd787 Engine, Exhaust, Transmission 59 01-02-2014 12:59 PM
Possible whp gains kjdd787 Engine, Exhaust, Transmission 0 12-26-2013 06:51 PM
ECU HP gains? ender2664 Engine, Exhaust, Transmission 45 03-31-2013 04:33 PM
