#197 |
The Fail Boat
Drives: CWP S.B.
No news?.
/cast rresurrection |
| The Following User Says Thank You to chaoskaze For This Useful Post: | Lantanafrs2 (10-06-2020) |
#198 |
Drives: 2013 frs red
#199 |
Drives: 19' Toyota 86 TRD
#200 |
#201 |
Because compromise ®
Drives: Red Herring
I would like to see the organic certification.
| The Following User Says Thank You to Captain Snooze For This Useful Post: | fika84 (02-05-2020) |
#202 |
The guy w/o an FRS or BRZ
Drives: '23 GR86 Premium 6MT Halo White
I want to learn everything I can about ITB's. Yesterday I learned that the OEM throttle body is used to operate the 4 ITB's through a mechanical linkage. I understand they did this probably to simplify the drive-by-wire environment.
My question: Is the OEM throttle body actuator robust enough to handle the increased load of 4 spring-biased valves and the linkage attached to them? |
| The Following User Says Thank You to ROFL it's Waffle For This Useful Post: | radroach (08-31-2020) |
#203 | |
My last car I just felt the turbo was very finicky, despite Mike's e-tune from Innovative Tuning. With my lack of experience in programming/electronic engine management (drive-by-wire), I'll have to side with you that N/A is my preferred way to go, just to simplify an already complex modern-day engine topic. |
#204 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Bumping this because I was thinking about ITBs and all the things. Any news out there? I know Delicious was working on something a while back.
#205 | |
Drives: JRSC BRZ SOLD
A couple guys on a FB group have delivered their result. Long story short the ITBs are too small for the engine. Great low end and midrange and losses of 15-20whp on the top end. |
#206 |
Ooof. I was expecting the opposite. Nothing down low and it all up top
#207 |
Señor Member
Ouch! Can you share what facebook groups? I'd still be interested in seeing the torque curves.
1974 TA22 Celica
2013 86 GT |
#208 |
Drives: ADM Toyota 86 GT
I'm no expert, but isn't it then just a matter of tuning the length and width of the runners to move the torque around?
Sent from my CPH1979 using Tapatalk |
#209 | |
I stand corrected. IIRC the one who lost power may of had cams. Here is an otherwise stock long block with a full exhaust on 93 using the supplied IM. ![]() You'll have to do some sifting but the info is there. https://www.facebook.com/groups/NaturallyAspirated86 |
| The Following User Says Thank You to PulsarBeeerz For This Useful Post: | Turdinator (10-06-2020) |
#210 |
Sooooo, pretty much as I said it would go.
| In for the long haul Ultimate NA build thread. | celek | Engine, Exhaust, Transmission | 683 | 06-07-2020 07:26 PM |
| TOG ULTIMATE TOYOTA 86 GT86 FT86 SUBARU BRZ FA20 STAINLESS STEEL EXHAUST HEADERTOG UL | Andrew666 | AUSTRALIA | 8 | 11-19-2018 05:24 AM |
| RallySport Direct's Ultimate Drivetrain Thread! ***New Website*** | RallySport Direct | Transmission and Driveline | 92 | 09-01-2015 01:17 PM |
| RallySport Direct's Ultimate Interior Thread! | RallySport Direct | Interior Parts (Incl. Lighting) | 45 | 03-25-2015 02:12 PM |
| Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! | THMotorsports.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 12-11-2013 06:25 PM |
