| Engine Swaps Discussion of engine swaps. |
#15 |
Drives: Q5 + BRZ + M796
That does seem low. Maybe packaging limited the size. I wonder if that can be a problem for cooling or oil pressure during cornering.
#16 |
#17 |
Drives: Many
Pretty much every SR has a high capacity pan: Greddy, Tomei, ARC, etc. They still only hold about 4.5 quarts though.
| The Following User Says Thank You to e1_griego For This Useful Post: | Irace86.2.0 (09-04-2020) |
#18 |
JHerbert Racing
Drives: 2013 Scion FRS
As a previous SR powered 240 owner I have dreamed about this swap ever since I bought my FRS. Even contacted Sikky and Wiring Specialties about it in 2014. I have been following this build and cannot wait to see them race it.
#19 |
JHerbert Racing
HPA is running a dry sump to remedy that. As well as to aid with subframe clearance.
| The Following User Says Thank You to Takumi788 For This Useful Post: | Irace86.2.0 (09-04-2020) |
#20 |
has a funny hat
Drives: 2014 BRZ Limited
Not only does he have a K powered BRZ, but it's run by the OEM ECM. It's an impressive build thread.
| The Following User Says Thank You to pope For This Useful Post: | solidsnake11 (09-05-2020) |
#21 |
Drives: 2019 Toyota 86 TRD SE
| The Following User Says Thank You to Drifter X For This Useful Post: | solidsnake11 (09-07-2020) |
#22 | |
Another video:
#23 |
JHerbert Racing
HPA has always been a great channel but this build really has me checking for new videos often. Not only is it a crazy swap, but it is a crazy swap that is designed to be functional in a race car. It doesn't get better.
| The Following User Says Thank You to Takumi788 For This Useful Post: | Irace86.2.0 (09-14-2020) |
#24 |
#25 |
#26 |
#27 |
Kinda sucks, right?
#28 |
Drives: 2015 FRS - FFR GTM
2015 FR-S - One Day I'll Finish The Swap |
| 2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members | Cookiemonster | Engine Swaps | 18 | 05-25-2019 01:40 PM |
| Dead RB25 Swap, Alive 2jz swap | -Phil | Engine Swaps | 72 | 09-15-2018 03:35 PM |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 11:54 PM |
| 1GR-FE Swap | tostidos | Engine Swaps | 36 | 11-26-2015 01:00 PM |
| Looking to do an SR20 Swap | nickw14 | Engine Swaps | 80 | 03-15-2015 03:02 PM |
