Old 09-28-2020, 03:00 PM   #15
WildCard600
WildCard600's Avatar
Drives: 2020 86
Originally Posted by Bonburner View Post
You mean the fan at the front of our car? Is it really that bad? I mean our coolant is so well cooled that I'm doubting it's the fan ...
No, not talking about the radiator fan. The blower fan that pushes the HVAC air through the vents inside the car. Compared to my jeep or wifes CHR the 86 blower is weak.
WildCard600 is offline   Reply With Quote
The Following User Says Thank You to WildCard600 For This Useful Post:
Bonburner (09-28-2020)
Old 09-28-2020, 03:28 PM   #16
86TOYO2k17
Drives: 2017 toyota 86
Originally Posted by Uncle86 View Post
but the replacing part is not as involved as replacing the radiator? I mean if thats the case I might aswell throw in a koyorad
Sent from my Pixel 4 XL using Tapatalk
Once the bumper is off they are both pretty similar.
Radiator you need to drain the coolant
AC you need to drain the AC at a shop with a machine.
Otherwise a couple bolts mounting them in place, and a couple hoses need to be pulled off. Really the physical swap is pretty easy and straightforward.
Then you need to fill and purge the coolant system for radiator
Take to a shop to refill the AC.
It would not be too much more involved to do one while doing the other.
Bad ball joint;possible to just replace balljoint or do I have to replace control arm kev0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 01-03-2019 04:07 PM
Have to replace entire assembly to replace fuel filter? tobkin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 08-04-2017 03:26 PM
WTB: A/C Condenser SmireyFase Want-To-Buy Requests 1 05-16-2017 09:28 PM
AC Condenser MicheleAbbate Engine, Exhaust, Bolt-Ons 1 05-17-2016 08:11 PM
WTB: A/C Condenser 86_ZN6 Engine, Exhaust, Bolt-Ons 13 08-21-2013 10:26 AM
