Old 09-19-2020, 04:27 PM   #15
JD001
JD001's Avatar
Drives: Subaru BRZ
oh, just leave it be!
Yeah, but we know what happens when things go into reverse.. further consequences leaving their indelible impressions.
The Following User Says Thank You to JD001 For This Useful Post:
humfrz (09-19-2020)
Old 09-19-2020, 07:40 PM   #16
What on earth are you getten at -
JD001 (09-20-2020), soundman98 (09-20-2020)
Old 09-20-2020, 12:15 AM   #17
Worst thread ever
JD001 (09-20-2020)
Old 09-20-2020, 12:34 AM   #18
Worst thread ever
humfrz (09-20-2020), JD001 (09-20-2020), soundman98 (09-20-2020), Spuds (09-20-2020), theneptune86 (10-05-2020), Ultramaroon (09-20-2020)
Old 09-20-2020, 02:41 AM   #19
Is that bolt out of your old clutch/transmission (the one with the blown TOB)?
JD001 (09-20-2020)
Old 09-20-2020, 09:08 AM   #20
No. I think it said it came out of the back bumper of a Saturn.
humfrz (09-20-2020)
Old 09-20-2020, 01:05 PM   #21
milanojess
milanojess's Avatar
Drives: 2013 FRS
Dude doesn't even know how much pad (if any) is left so what good is bedding it going to do?
If op doesnt have that knowledge, then he/she should go to shop
On the other hand, it pads is gone and backing plate is hitting rotor, you would get some vibration, metal to metal grinding noise, and reduced brake efficiency. And if rotor is under spec, you run into danger of brake pad dropping out from caliper, then you would loose brake completely
Op doesn’t seem to experience any of that so I feel at least some pad materials are still present.
Again, if one doesn’t know how to identify how much pad is left, one really should take it to the shop. It’s for the safety, of op and of others on road
2013 FRS - JRSC CARB
"Use all of the track" they say
milanojess is offline   Reply With Quote
Old 09-20-2020, 04:36 PM   #22
Probably, guessing from the description, there is a little pad left but the wear indicators are touching the rotors. That is why it only appears with certain brake pressures.
Even if it isn't the problem checking pad thickness should be the very first thing done with these symptoms. Assuming they are fine and trying to fix it through other means or looking for other issues is just pissing into the wind.
humfrz (09-20-2020)
Old 09-20-2020, 05:40 PM   #23
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Who runs "several thousand miles" with a known problem? Good news is you can get a good deal on pads and rotors together.
PetrolioBenzina is offline   Reply With Quote
Old 09-20-2020, 07:29 PM   #24
soundman98
ProCrastinationConsultant
soundman98's Avatar
my clutch squeaked for a good 10-15k miles.
knew it needed a fluid change, just never got around to it.
i've got a whiteboard by my back door with all the things that should be done, can be done, and i want to do. priority is given to which part breaks first.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
humfrz (09-20-2020), theneptune86 (10-05-2020)
Old 09-20-2020, 07:47 PM   #25
Well, at least you have things written down on a list -
soundman98 (09-21-2020)
Old 09-20-2020, 08:39 PM   #26
PetrolioBenzina
Drives: 17 86
Questionable brakes would be at the top of my list.
The Following User Says Thank You to PetrolioBenzina For This Useful Post:
humfrz (09-20-2020)
Old 09-21-2020, 12:20 AM   #27
soundman98
soundman98's Avatar
otherwise, i forget!
humfrz (09-21-2020)
Old 09-21-2020, 12:42 AM   #28
I find that if I don't write things down, I forget, then they didn't exist -
DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video continuecrushing DIY (Do-It-Yourself) Guides 44 11-23-2020 07:17 PM
17+ Taillights, 4th Brake Light, Valenti Brake Light Harness, PPF & More kashmir Exterior Parts (Aero, Lighting, Etc.) 7 12-11-2019 03:42 AM
DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) BirdTRD DIY (Do-It-Yourself) Guides 17 11-06-2017 09:42 PM
Valenti 4th brake light vs Valenti Style brake light? JGalp Electronics | Audio | NAV | Infotainment 9 03-24-2016 06:48 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
