Old 09-18-2020, 12:50 PM   #1
szjalo
Drives: 2014 Scion FR-S
inconsistent brake squeaking, only happens with light brake
Hi I have experienced a situation a couple thousand miles ago. My rear brakes start to make a squeaking noise when brake lightly. Hard brakes (brake pedal all the way down) are completely silent. Light brakes (<1/3 brake down) makes a high pitch noise. This is also much more frequent at low-medium speed (30-50 mph). When brake over 60mph, this rarely happens. This also only happen in the first few brakes in a period of time.
For example, I drive on freeway (>70mph), no noise--> hard brake into ramp, no noise) --> drive on local roads (~40mph), lots of noise on light braking --> continue to drive on local roads (more than 4-5 stops later), noise goes away.
Brake pads not brand new but should still have some life left. No visible wear/loose on brake clips.
Any insight?
Thanks
szjalo is offline   Reply With Quote
Old 09-18-2020, 01:35 PM   #2
Hi ya, szjalo -
How many miles on those brake pads?
Are they OEM pads, if not what kind?
Do you track your car much?
Have you had your wheels off and inspected the pads?
Maybe they are worn down to the wear indicators (whatever they are called)?
Maybe the pads are glazed?
Come back.
Spuds (09-18-2020)
Old 09-18-2020, 03:11 PM   #3
Thanks
"Should" or do?
Start with and actual check of the pads and then move on from there.
humfrz (09-18-2020)
Old 09-18-2020, 04:57 PM   #4
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Visual inspection.
Then I'd apply some grease to the back of the pad.
RToyo86 is online now   Reply With Quote
Old 09-18-2020, 05:49 PM   #5
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Any insight?
Thanks
Don't wait "a couple thousand miles"?
PetrolioBenzina is offline   Reply With Quote
Old 09-19-2020, 10:27 AM   #6
milanojess
milanojess's Avatar
Drives: 2013 FRS
Try repeat a brake pad bedding procedure, that usually clears minor noises when light braking, often caused by slight glacing of pad/rotor
2013 FRS - JRSC CARB
"Use all of the track" they say
milanojess is offline   Reply With Quote
Old 09-19-2020, 10:33 AM   #7
JD001
JD001's Avatar
Drives: Subaru BRZ
I have an urge to say something... Something to do with design, shit and can't see the pads.. But I can't place it into a sentence..
The Following 7 Users Say Thank You to JD001 For This Useful Post:
humfrz (09-19-2020), NoHaveMSG (09-25-2020), soundman98 (09-19-2020), Spuds (09-20-2020), Tcoat (09-19-2020), theneptune86 (10-05-2020), Ultramaroon (09-20-2020)
Old 09-19-2020, 11:20 AM   #8
soundman98
ProCrastinationConsultant
soundman98's Avatar
i love when my brakes squeal for a second on that initial pad contact. it helps me know that they're still there.
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
guitarman (09-19-2020), humfrz (09-19-2020), JD001 (09-19-2020)
Old 09-19-2020, 12:18 PM   #9
Dude doesn't even know how much pad (if any) is left so what good is bedding it going to do?
JD001 (09-19-2020), Ultramaroon (09-20-2020)
Old 09-19-2020, 12:33 PM   #10
JD001
JD001's Avatar
Drives: Subaru BRZ
I'm struggling.. really, really struggling.. my brain in reverse gear...
The Following User Says Thank You to JD001 For This Useful Post:
Old 09-19-2020, 01:09 PM   #11
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
The Following 3 Users Say Thank You to bcj For This Useful Post:
humfrz (09-19-2020), ToySub1946 (09-19-2020), Ultramaroon (09-20-2020)
Old 09-19-2020, 01:54 PM   #12
PetrolioBenzina
Drives: 17 86
Any updates, OP?
Old 09-19-2020, 04:12 PM   #13
Sort of like back-in-the-day, when we used to "pump" the brakes, to make sure they were "up" to the task.
soundman98 (09-19-2020), Ultramaroon (09-20-2020)
Old 09-19-2020, 04:14 PM   #14
oh, just leave it be!
JD001 (09-19-2020)
DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video continuecrushing DIY (Do-It-Yourself) Guides 44 11-23-2020 07:17 PM
17+ Taillights, 4th Brake Light, Valenti Brake Light Harness, PPF & More kashmir Exterior Parts (Aero, Lighting, Etc.) 7 12-11-2019 03:42 AM
DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) BirdTRD DIY (Do-It-Yourself) Guides 17 11-06-2017 09:42 PM
Valenti 4th brake light vs Valenti Style brake light? JGalp Electronics | Audio | NAV | Infotainment 9 03-24-2016 06:48 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
