Drives: 2014 Scion FR-S
inconsistent brake squeaking, only happens with light brake
Hi I have experienced a situation a couple thousand miles ago. My rear brakes start to make a squeaking noise when brake lightly. Hard brakes (brake pedal all the way down) are completely silent. Light brakes (<1/3 brake down) makes a high pitch noise. This is also much more frequent at low-medium speed (30-50 mph). When brake over 60mph, this rarely happens. This also only happen in the first few brakes in a period of time.
For example, I drive on freeway (>70mph), no noise--> hard brake into ramp, no noise) --> drive on local roads (~40mph), lots of noise on light braking --> continue to drive on local roads (more than 4-5 stops later), noise goes away. Brake pads not brand new but should still have some life left. No visible wear/loose on brake clips. Any insight? Thanks |
#2 |
Hi ya, szjalo -
![]() How many miles on those brake pads? Are they OEM pads, if not what kind? Do you track your car much? Have you had your wheels off and inspected the pads? Maybe they are worn down to the wear indicators (whatever they are called)? Maybe the pads are glazed? Come back. |
| The Following User Says Thank You to humfrz For This Useful Post: | Spuds (09-18-2020) |
#3 | |
Start with and actual check of the pads and then move on from there.
| The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (09-18-2020) |
#4 |
Drives: 17 Asphalt 86
Visual inspection.
Then I'd apply some grease to the back of the pad. |
#5 |
Drives: 17 86
#6 |
Drives: 2013 FRS
Try repeat a brake pad bedding procedure, that usually clears minor noises when light braking, often caused by slight glacing of pad/rotor
2013 FRS - JRSC CARB
"Use all of the track" they say |
#7 |
Drives: Subaru BRZ
I have an urge to say something... Something to do with design, shit and can't see the pads.. But I can't place it into a sentence..
| The Following 7 Users Say Thank You to JD001 For This Useful Post: | humfrz (09-19-2020), NoHaveMSG (09-25-2020), soundman98 (09-19-2020), Spuds (09-20-2020), Tcoat (09-19-2020), theneptune86 (10-05-2020), Ultramaroon (09-20-2020) |
#8 |
ProCrastinationConsultant
i love when my brakes squeal for a second on that initial pad contact. it helps me know that they're still there.
#9 | ||
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | JD001 (09-19-2020), Ultramaroon (09-20-2020) |
#10 |
Drives: Subaru BRZ
| The Following User Says Thank You to JD001 For This Useful Post: | Ultramaroon (09-20-2020) |
#11 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
"I gotta rock." -- Charley Brown Last edited by bcj; 09-19-2020 at 01:50 PM. |
| The Following 3 Users Say Thank You to bcj For This Useful Post: |
#12 |
Drives: 17 86
Any updates, OP?
#13 |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | soundman98 (09-19-2020), Ultramaroon (09-20-2020) |
#14 |
| The Following User Says Thank You to humfrz For This Useful Post: | JD001 (09-19-2020) |
| DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video | continuecrushing | DIY (Do-It-Yourself) Guides | 44 | 11-23-2020 07:17 PM |
| 17+ Taillights, 4th Brake Light, Valenti Brake Light Harness, PPF & More | kashmir | Exterior Parts (Aero, Lighting, Etc.) | 7 | 12-11-2019 03:42 AM |
| DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) | BirdTRD | DIY (Do-It-Yourself) Guides | 17 | 11-06-2017 09:42 PM |
| Valenti 4th brake light vs Valenti Style brake light? | JGalp | Electronics | Audio | NAV | Infotainment | 9 | 03-24-2016 06:48 PM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 11:20 PM |
