Old 09-12-2020, 03:13 AM   #1
j_ros94
Drives: 2017 Subaru BRZ
Boosted brz hissing noise
I never noticed this before but whenever i accelerate i hear a hissing noise but once i remove my foot off the gas the bov goes off and the hissing stops. Is that turbo spool? Just never noticed it before
Sent from my SM-G960W using Tapatalk
j_ros94 is offline   Reply With Quote
Old 09-12-2020, 06:56 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
It's probably just the turbo. Can you provide an example of the sound? It could be a boost leak at a clamp, but unlikely.
I'm sure that it's just the turbo spooling up.
p1l0t (09-12-2020)
Old 09-12-2020, 11:52 AM   #3
p1l0t
p1l0t's Avatar
Did you double post?
To the GALLOWS! (or I guess just merge the threads)
Old 09-12-2020, 05:16 PM   #4
jflogerzi
jflogerzi's Avatar
Turbo surge or whatever it's called?
2013 Series 10 FRS #553
Old 09-13-2020, 11:26 AM   #5
j_ros94
It probably just is the turbo cuz it only starts hissing at 4k rpm while driving i dont hear it his while stopped and revving my engine
Old 09-13-2020, 02:40 PM   #6
p1l0t
p1l0t's Avatar
Yeah that's probably when your turbo starts making more pressure than you need and it starts to dump the excess.
Hissing noise j_ros94 Forced Induction 7 10-07-2020 09:02 PM
Hissing noise after turning off car Coop Issues | Warranty | Recalls / TSB 7 09-14-2018 02:28 PM
Hissing/ticking sound under load NyX_Nick Engine, Exhaust, Transmission 8 06-05-2018 10:01 PM
Hissing/rattle from 3.5-4k RPM after OFT illmatic_frs Engine, Exhaust, Transmission 28 03-21-2017 09:02 PM
Hissing clutch noise FR-Sky Issues | Warranty | Recalls / TSB 32 02-16-2017 11:57 PM
