#4257 |
Noodleking
Drives: 2013 Firestorm FRS
Oh, just as an update.. I ended up ordering a new hub for the supercharger and another 30mm track pack. The new pulleys definitely have less play than the last set (I recall when I got my last set, I sent an email out to Kraftwerks about the play-- they did respond, but I figured it wasn't a huge deal), buttoned it back together and have been back on the road. Hopefully now, with everything all spec'd right, I'll get another year before something else crazy happens
2013 Firestorm FR-S, Kraftwerks C38 kit, FT-86 UEL Catted Headers, TRD D-Tip cat-back, Vibrant 1140 Resonator, Exedy Stage 1 Normal/smoother clutch that replaced the Stage 2 3-puck clutch, Exedy Lightweight flywheel, DSS carbon fiber driveshaft, TEIN springs on performance package Sachs dampers, Megan Racing Inner tie rods, 17x8 +35 Enkei Silver RPF1's, OS-Giken 1.5-way diff, J-Luth steering wheel and now a GKTech angle kit-- which rubs.
#4258 |
Drives: Whiteout FR-S, Evo 8 RS
Anyone having issue with belts having varied tension? Mine goes from 64hz - 74hz when turning the crank 180 degrees. I called KW about this weirdness and Joel said the crank may be spinning in a slightly oval pattern. I marked the crank position to the tightest point at 74hz, then released and tightened the crank bolt, but all the tension went to the other side instead.
Upon removing the crank pulley and adapter I noticed there being some play between them. I tried putting some tape in there to make it a bit more solid but there were no changes, it still reads 64hz to 74hz. Any ideas? |
#4259 |
Drives: 1996 ST204, Series 10 FR-S
@D-VO
Seems like your best bet is to use a dial indicator with a magnetic stand to measure runout. Either one of your idlers, supercharger pulley or crank pulleys can cause the belt to change tension as you rotate the crank since it is a cogged system. Heck, even an unevenly stretched belt could cause that. So many different variables. @ichitaka05 It seems like the OP @digital_assassin has sold his 86 and no longer visits this site. Is there any way I can take over and update the first post? I would like to update the replacement belt part numbers as the one listed is no longer relevant. I ordered the wrong one because the post is outdated. Thanks |
#4260 | |
Site Moderator
Drives: ichi 86 Project
#4261 |
Drives: 2015 frs, 2000 Honda s2000,
this is 94, not 91, but stock headers, stock exhaust, kraftwerks kit made 265whp with the 90mm pulley.
on a side note can anyone let me know if this tune looks good? He lowered the redline to 7300rpm and it runs a little lean at that point. Didn't seem like I was running out of fuel, just seemed a little weird is all. https://imgur.com/a/FMsQrqd |
#4262 |
Also Has anyone done 10-15 minute hot lapping sessions with this kit? What should I know, what should I be careful with? I'm so paranoid about blowing up the supercharger from oil starvation or something.
#4263 |
Drives: frs
My kraftwerks pulley is hitting the oil filter. Did i misaligned the brackets or is something else wrong?
https://imgur.com/gallery/67VrEgD |
#4264 | |
#4265 | |
Drives: frs
I was wondering if anyone had that problem. Will take the whole bracket out and redo the pulleys to see if thats an issue. |
#4266 |
Drives: Scion FR-S
Not sure if this related to my Kraftwerk Race version supercharger or not.
The problem I have now is that when engine gets warm it stalls... Several tune revisions were loaded before with this problem ocurred. Openflash was in the process of leaning off the engine, and since tune #9 it started happening, trying to flash to earlier versions did not help, so something is broken... I was told to check exhaust for leaks and supercharger pipe leaks. Fixed a small pinhole in exhaust half way down, found some minor boost leaks and fixed them (except Rotrex output swirl is leaking at the base is still to be fixed) but the problem persists. How do I recognize if the engine is damaged? Anyone an idea? |
#4267 |
Drives: brz 2017 hksv2
post log..
#4268 | |
Drives: FT86
check LTFT is less than 10% assume its stalling at idle or throttle lift off. check afr at idle is arround 14.7 also check monifold pressure boost on oft is about -10 psi at idle if its only like -6 likely intake or bov leak. if all ok increase ithe overu fuel resume to 1500 and bump idle to 800 rpm |
#4269 |
Drives: Scion FR-S
Yes, you are correct its stalling when warm at idle or when I come to a traffic light and throttle is off.
I missed to mention that 2 months ago was last email from my tuner ( who seems to have abandoned me) and he sent me the ECU file with raised idle rpm to 1k which suppose to be helping him troubleshoot the problem. I sent the logs but never heard back from him yet. See attached log file. this with idle raised and in warm state of engine and no throttle. |
#4270 |
you have extreme positive fuel trims
check for exhaust leak near the lambda sensor |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
