| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: '13 BRZ in WRB--let's mod!!!
Can anyone confirm if TWS T66-F Wheels 18x9.5 +45s clear Brembos?
If car has coilovers? Searched all over & could not get confirmation.
TIA
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD * '22 Z51 Vette--sold. * '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties. * '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot. |
#3 |
Drives: 2022 GR86
Assuming you know about more wheels than already listed on this post, the community would definitely appreciate if you could share more info on that thread.
#4 |
Well... I just pulled a trigger on a set--so I sure hope they'll clear lol
Seriously, per their site, they will. I'll post up pics once mounted to verify.
#5 |
You got some BADASS wheels.
With the +45 offset, depending on the tires you run and/or suspension, you may want to run spacers to not rub the tire at full lock. |
#6 | |
MCS coilovers & 275s (actually A052s Yoks in 265, but they're as wide as most 275s). Will be running -3 in front & -2 rear. Should I be able to get by without rolling? Thanks. |
#7 | |
Drives: 2016 Toyota 86
You might rub the inner tire on the coilovers with 275s. |
#8 |
#9 |
^^^ thinking abt that, too. Ran +42 Mach V 18x9.5s w/ 275 Hoosiers on my old Turbo FR-S & no issues. But... Was only running ~-2.3in front w/ that setup. -3 may be an issue. So a 3mm spacer effectively gets me back to +42.
Thanks, guys... |
#10 |
Confirmed: yards (or at least fingers) to spare for clearance.
Getting some rubbing, but trying to determine where. The car may be a bit too low in the front. Will try raising it slightly to see if that works. Running -3.2 degrees camber up front. Rears have zero issues w/ -2.2 265 Yoko A052s square setup. Very neutral setup & fantastic turn-in. ![]() ![]()
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD * '22 Z51 Vette--sold. * '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties. * '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot. Last edited by GTB/ZR-1; 01-12-2021 at 04:29 PM. |
#11 |
Drives: 2022 GR86
Thanks for the info, added to the PP Brembo thread
| The Following User Says Thank You to timurrrr For This Useful Post: | GTB/ZR-1 (01-12-2021) |
| Which wheels clear 17+ BRZ Performance Package Brembos | timurrrr | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 381 | 11-03-2025 05:30 PM |
| Finding wheels to clear brembos | jojosbrz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 11-13-2018 09:46 AM |
| Aftermarket lug nuts on stock wheels: confirm? | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 27 | 09-19-2018 08:38 PM |
| Do BRZ/FRS/GT86 wheels fit over rear Brembos? | Elliotw | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 06-13-2018 05:30 PM |
| just to confirm..about 15inch wheels | thebus | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 05-07-2014 05:32 PM |
