Old 08-31-2020, 07:45 PM   #1
echomx
Drives: '13 subaru brz
What parts would I need to completely replace entire suspension system?
I'd like to completely redo my suspension. I'm at 112,000 miles, it just seems so worn out, and from what I can see without lifting up the car, a lot of the suspension is rusted from winter driving.
Most likely I will go with the Bilstein B6 + RCE Yellow combo. Seems everyone is happy with this combo.
Aside from Rear LCA & Front Camber bolts, what else would I need to grab to do this. Anything that might be worn I'd rather replace for peace of mind.
echomx is offline   Reply With Quote
Old 08-31-2020, 07:48 PM   #2
Jdmjunkie
Drives: Scion FR-S 10 Series
I would recommend checking and replacing worn bushings.
Jdmjunkie is offline   Reply With Quote
The Following User Says Thank You to Jdmjunkie For This Useful Post:
finch1750 (08-31-2020)
Old 08-31-2020, 09:37 PM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
All those mentioned plus ball joints.
Tie rods inner/outer if they look beat to hell.
Old 08-31-2020, 11:46 PM   #4
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I would check sway bar bushings and end links for sure. Mine were both completely toast sometime before150k miles
norcalpb (09-01-2020)
Old 08-31-2020, 11:52 PM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Definitely look into the white line outrigger bushings for the diff! Quick and easy
Old 09-01-2020, 09:00 PM   #6
echomx
Thanks for the responses. Writing all this down to research a plan. What about the sway bar itself? Mine looks pretty rusted.
Old 09-02-2020, 10:36 AM   #7
Racecomp Engineering
I've been meaning to put together a detailed post on this subject.
Out of curiosity, how bad does your swaybar look? Got a pic?
- Andrew
wparsons (09-05-2020)
Old 09-02-2020, 10:00 PM   #8
echomx
That would be awesome!
I can take a pic in the next day or two.
Old 09-03-2020, 07:58 PM   #9
echomx
A few other questions.
I see listings for B6's with and without blue boot. Is there a reason why there are two versions? Does it come with boot? If not is there an aftermarket one I can buy?
Also, would anyone recommend any of the bushing kits? There's the Whiteline kit that comes with the camber bolt kit I'd need anyway. Worth getting anything else?
Old 09-04-2020, 10:24 AM   #10
We get our Bilstein B6 direct from Bilstein....I'm guessing the different pics you're seeing are just people taking photos with the boots left off.
Post coming today!
- Andrew
Old 09-04-2020, 11:47 AM   #11
https://www.ft86club.com/forums/showthread.php?t=142230
Have to replace entire assembly to replace fuel filter? tobkin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 08-04-2017 03:26 PM
FS: Entire Exhaust System Need Gone! 86Hiro Engine, Exhaust, Bolt-Ons 30 04-19-2016 11:19 AM
Replace entire OEM clutch assembly, or disc? radroach Engine, Exhaust, Transmission 8 08-08-2014 12:00 AM
ENTIRE Audio System for Sale DatDudeLoso Exterior Parts (Aero, Lighting, Etc.) 2 10-27-2013 09:24 PM
Entire Drivers Side Electrical Panel completely dead Asphalt~86 Issues | Warranty | Recalls / TSB 13 11-14-2012 03:08 PM
